Upper alternator bracket bolt
Old Jul 22, 2009 | 07:49 PM
StealthLT4's Avatar
StealthLT4
Default Upper alternator bracket bolt
Can anyone tell me the thread type on the bolt that connects the upper/rear support bracket to the alternator? It's not the same bolt as the compressor, and nothing I've stuck in there seems to work, which is a bad approach in the first place. It somehow fell out after I installed my headers, ever though my 'assistant' swears he reinstalled the bolt...
Thanks in advance!
EDIT: Here is a picture of the bolt I am talking about. It's the missing one...
Old Jul 22, 2009 | 10:33 PM
StealthLT4's Avatar
StealthLT4
ttt
Old Jul 22, 2009 | 11:26 PM
hip's Avatar
hip
Default back alt. bolt
back top alt. bolt thru bracket 5/16
Old Jul 23, 2009 | 04:55 PM
StealthLT4's Avatar
StealthLT4
It's much bigger than 5/16. Here's all the stuff I've tried; the only thing that will thread in there is the M10x1.5, but it doesn't feel like it's fully engaged. Like that's not the real thread, but it's catching.
7/16-14
7/16-20
1/2-13
1/2-20
M10x1.5
M12x1.75
I'm stumped. There aren't any other thread sizes at the hardware store close to that diameter. Right now I have an M10 stuck in there, but if I try to really torque down on it I can feel it stripping the threads, so I really don't think that's the right size.
Old Jul 23, 2009 | 05:13 PM
JAKE's Avatar
JAKE
If you're referring to the support brace, one end to the exhaust manifold and the other end to the alternator, mine is metric and stamped on the head of the bolt is "M 9.8"
Hope this helps.
Jake
West Point ROCKS!
Old Jun 3, 2012 | 05:43 PM
StealthLT4's Avatar
StealthLT4
Update 6/3/12: I added a picture, since I am doing a bunch of work on the car and figure I'll give this thing another go. Anyone have one they can measure, or know the thread? "M 9.8" means it's metric, but the 9.8 is just the grade (kind of like Grade 8 for SAE).
Old Jun 3, 2012 | 08:48 PM
WVZR-1's Avatar
WVZR-1
It actually I believe is 10 X 1.50 X 30mm and 26mm of threads. The original part # is no longer available but the replacement 11516328 should be very easy to find. It would have the correct flange head also. The original bolt was a 10.9 grade and I believe the newer is also.
Someone may have actually attempted a 3/8 bolt and ruined the threads or maybe they're actually destroyed.
If you want to find out I guess the easiest way would be have a parts store pull an alternator off the shelf!!!
I believe what is confusing is the one that is hidden behind the ASR in your snapshot on the end of that same bracket is actually 3/8 X 16
Old Jun 3, 2012 | 11:53 PM
Chuck Tribolet's Avatar
Chuck Tribolet
Sounds like it's Helicoil time.
Chuck
Old Jun 4, 2012 | 01:36 AM
WVZR-1's Avatar
WVZR-1
Chuck
Time-sert !
Old Jun 4, 2012 | 11:32 AM
96GS#007's Avatar
96GS#007
Originally Posted by WVZR-1
Time-sert !
Old Jun 4, 2012 | 04:37 PM
StealthLT4's Avatar
StealthLT4
Thanks for the replies. I remember that a 10x1.5 did not fit properly, so your comment about a 3/8" being tried may be true. I'm probably going to try tapping it back to 10x1.5, but if that doesn't work its Helicoil/Time-Sert time!
Old Jun 4, 2012 | 04:49 PM
383vett's Avatar
383vett
I boogered mine up years ago and tapped it for a 3/8x16 bolt. Works nicely.
Old Jun 4, 2012 | 11:50 PM
WVZR-1's Avatar
WVZR-1
Are you sure? 3/8 = .375 = 9.525 mm
To Upper alternator bracket bolt
