Okay, so 12 volt ain't my bag. My 94 seat switchs aren't right. the driver side powers with the driver/pass switch in either position, but the passenger side does make noise. Anyone expierience this?
the inflator switchs don't work or the bladders are bad. Opinions?
Thanks!
The seat bottoms are easy to remove. Start with a check for broken/disco wires. I think you will wind up pulling the switches though. A few minutes with an ohm meter will quickly reveal any problems with the switches once you get them off. Odds are very much in favor of the latex glove trick fixing your inflators.
I just fixed the same problem with my '96. The lumbar worked fine for either seat, but only the driver's seat moved with the switch in either the ds or ps position. Under the drivers seat bottom, there are only two connections that can be crossed. check the two black connectors and see if switching them around fixes the problem...
