4+3 Overdrive out
Old Feb 14, 2002 | 03:39 PM
mt_789's Avatar
mt_789
Default 4+3 Overdrive out
Not sure how serious a problem I have. Started driving to work this morning, and when I hit 2nd gear, the OD light did not come on as usual. Tried to turn it on with the switch on the gearshift, no luck. Same problem with 3rd and 4th. Did I just blow the fuse for the OD, or is there a more sinister problem? Any ideas? I think it might be the fuse because I noticed the console light that shines down from the rear view mirror was out, could they be in the same fuse? everything else seems to be ok... Had no time to check the fuses, and drove the truck to work instead.
Old Feb 14, 2002 | 05:03 PM
ZylaRace's Avatar
ZylaRace
Default Re: 4+3 Overdrive out (mt_789)
What Year?
Fuse is easy enough to check.
Old Feb 14, 2002 | 05:06 PM
Dave's_88's Avatar
Dave's_88
Might be a fuse...might also be the overdrive switch itself. I'm not positive where it is (connects to the OD button on shifter). My OD had the same symptoms, had the switch changed, problem solved.
Old Feb 14, 2002 | 05:38 PM
mt_789's Avatar
mt_789
Default Re: 4+3 Overdrive out (ZylaRace)
It is an 88. If the swich went bad, would it completely knock out the overdrive? I guess I will find out when I get home if a fuse blew ( I hope so)
Old Feb 14, 2002 | 06:06 PM
scorp508's Avatar
scorp508
If the switch was dead, the OD would still activate and the light on the dashboard would come on. Your '88 has the identical program to my '87 (the only two years that do).
I would test the overdrive relay in the engine compartment to see if it has gone bad. I had a loose wire in mine cause this condition before. Then I would hit a bump and it would engage. A real pain. :)
[Modified by scorp508, 5:07 PM 2/14/2002]
Old Feb 14, 2002 | 06:45 PM
David-F's Avatar
David-F
You might have to get a hold of a scanner and take a look you could have a number of problems on of which could be that first gear switch if the ECM thinks the car is still in first it will not turn the O/D on. The relay has nothing to do with the LCD O/D light unlike the 84 to 86 if the O/D does not come on it's because the ECM is not turning it on so there is were you need to start. Unplugging the first gear switch should siginal the ECM that the car is not in first so try this and see if the O/D comes on. If it still does not come on you would have to get a scan tool and check data to make sure coolant temp is correct and also TPS is working correctly if everything looks good you may have a problem with the ECM. Now if the O/D light up in the LCD and the O/D does not work then I would check the relay, but with out the O/D light in the LCD you need to fine out why the ECM is not turning it on.
David Fulcher
Old Feb 14, 2002 | 06:47 PM
scorp508's Avatar
scorp508
Default Re: 4+3 Overdrive out (David-F)
Bah! I guess I was way off. :)
Old Feb 14, 2002 | 07:51 PM
Rich B.'s Avatar
Rich B.
Default Re: 4+3 Overdrive out (Dave's_88)
I'm not positive where it is (connects to the OD button on shifter)...
It's down near the bottom of the shift lever...These seem to go bad pretty often (coff *Scorp* coff), but after you've had the trans console apart 8 - 10 times, it gets pretty easy...You need to take the glove box lid, shift **** & Reverse rod, radio & AC fascia, DigiDash fascia, and console (shifter) cover off, then you can get to the switch...
The switch itself only costs about ~$12 from Newark Electronics (www.newark.com), or ~$70 from various aftermarket sources...
The part #'s are 61F752 (1985 On/Off) and 61F753 (1986+ Momentary Contact).
Old Feb 14, 2002 | 07:52 PM
scorp508's Avatar
scorp508
Default Re: 4+3 Overdrive out (Rich B.)
I know not what you speak of. :jester
Old Feb 14, 2002 | 08:13 PM
mt_789's Avatar
mt_789
Default Re: 4+3 Overdrive out (scorp508)
Thanks everyone for your help. It looks like I have my work cut out for me! And I was counting on just a burned out fuse! I should know better...
Old Feb 15, 2002 | 12:29 AM
A's Avatar
A
Hey where is this relay that you guys are talking about? My 4+3 would never engage, but the switch would activate and deactivate the little D on the gauges just fine.
Probably my problem is a sick sick OD unit (we'll find out soon when we crack it open) but it would be nice to have some ideas just incase for when it's all rebuilt and still doesn't work :D <knock on wood>
Old Feb 15, 2002 | 12:41 AM
scorp508's Avatar
scorp508
It is just to the right (if sitting in the driver seat) and behind the brake booster. There are 2 of them right there together. The rear-most one is the overdrive.
Old Feb 15, 2002 | 04:21 PM
Rich B.'s Avatar
Rich B.
...I think Troy put this icon in here just for Scorp...--> :smash:
Old Feb 15, 2002 | 04:23 PM
scorp508's Avatar
scorp508
:lol:
Old Feb 15, 2002 | 07:55 PM
myblack864+3's Avatar
myblack864+3
You might want to check the WOT (wide open throttle) swich. This switch over-rides commands from the computer to shift the o/d unit.. If you accelerate hard in first it allows you to shift in direct all the way to 4th without going into o/d. If the switch goes bad it may be telling the computer that you are at wide open throttle position and keep the unit in o/d until about 120 mph where it will shift regardless of throttle position. Good Luck
Old Feb 15, 2002 | 08:05 PM
scorp508's Avatar
scorp508
Default Re: 4+3 Overdrive out (myblack864+3)
I thought the TPS sensor was what fed the ECM the info needed to calculate WOT and downshift and deactivate OD until 4th?
Old Feb 15, 2002 | 08:06 PM
myblack864+3
Sorry :smash: :smash: :smash:
I made a mistake in my last post about the WOT switch. Last line should read "it blocks the o/d until about 120 mph when the WOT command is overridden and the o/d kicks in. :seeya
Old Feb 17, 2002 | 07:03 AM
Ray Quayle's Avatar
Ray Quayle
- 1986 Original Owner -
Cruise-In I Veteran
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In IV Veteran
Cruise-In VII Veteran
I'm with scorp here. Please enlighten us on the location of this mysterious WOT switch.
Old Feb 17, 2002 | 01:13 PM
scorp508's Avatar
scorp508
The auto OD upshift in 4th at WOT happens only in 85-88.
1985: 110mph
1986: 103mph
1987: 103mph
1988: 103mph
To 4+3 Overdrive out
