Smog question high HC (ppm)
Old Jul 24, 2009 | 07:30 PM
Kool88vette's Avatar
Kool88vette
Default Smog question high HC (ppm)
My 305 GMC pick up with 155,00 just barely passed a smog with a reading of 95 HC (ppm) That's the max allowed. The NO is high too. 789 at 15 mph and 232 at 25 mph. Can someone tell me what's wrong? It runs perfect.
Old Jul 24, 2009 | 07:58 PM
Kool88vette
I did a little research. I guess the problem is unburned fuel. I'm guessing it's the cat because everything is stock and runs fine.
Old Jul 24, 2009 | 10:35 PM
GKK's Avatar
GKK
High NOX levels are the result of high combustion temperatures.
Is the EGR valve working correctly and do you have a free flowing exhaust which reduces the backpressure needed for the EGR valve to operate?
Did you do a complete tune up before the emission test too include an oil change, spark plugs, cap, rotor, O2 sensor, air filter and timing?
All of the above will contribute to high HC levels.
Old Jul 25, 2009 | 10:46 AM
Kool88vette
Thanks, I think it needs a tune up.
To Smog question high HC (ppm)
