84 Fuel Pump Issue
Old Jul 24, 2009 | 10:28 PM
schwefel's Avatar
schwefel
Default FIXED: 84 Fuel Pump Issue
FIXED!!! It was the Oil Pressure Switch
My fuel pump is coming on when turing on the ignition, going up to pressure then nothing.
It is carbed. The pump comes on, fills the bowl then stops. (seems normal so far.) When the car starts the pump never kicks back on.
I am pretty certain that I have fuel pressure above 4psi. My cluster is shot, though. (With as many times as I have started/restarted it under this condition, it would have siezed if no oil pressure.)
Any thoughts as to why it would be doing this? What to look for? Bad sending unit?
Please help.
Jason
Old Jul 25, 2009 | 12:31 AM
schwefel's Avatar
schwefel
I am reading that the the ECM will energize the pump relay when it see pulses coming from the distributor. With mine being converted to carb, with a standard vac advance type distributor, there would be no pulses for the ECM to see, right?
Old Jul 25, 2009 | 09:31 AM
schwefel's Avatar
schwefel
Anyone?
ttt
Old Jul 25, 2009 | 10:42 AM
joe wilson's Avatar
joe wilson
If you've changed distributors you probably aren't getting a pulse. If you just used a plain distributor from say a 1975 Chevy with one wire you won't be sending the pulse. So why not just re-wire or change the fuel pump to one that runs all the time the ignition is on?
You probably could have kept the factory distributor when going to carb if you wanted. I did that on a car I used to have. It did all right. You'll need a good working oil pressure gauge because the automatic shutoff won't be there.
Old Jul 25, 2009 | 11:00 AM
jhammons01's Avatar
jhammons01
^^isn't there an oil pressure power loop?? In other words, there is a power loop that makes the pump work when there is oil pressure??
I'm not sure on that, I think I read it somewhere.
Old Jul 25, 2009 | 12:12 PM
schwefel's Avatar
schwefel
Fixed, see OP
To 84 Fuel Pump Issue
