Intake manifold gaskets
Old Jul 26, 2009 | 01:05 PM
LBYRNES's Avatar
LBYRNES
Default Intake manifold gaskets
There are the two logical gaskets that go between the block and the intake manifold, (Similar to the exhaust manifold), however, the FSM doesn't show anything for the area around the outside edge of the intake manifold. Does it just sit there, or do we just put some RTV around the outside edge?
Old Jul 26, 2009 | 01:11 PM
STL94LT1's Avatar
STL94LT1
On the LT1 you have to put sealant on the front and rear block china walls. Put a decent size bead of RTV on each.
Old Jul 26, 2009 | 01:20 PM
LBYRNES's Avatar
LBYRNES
Thanks for your help.
Larry...
Old Jul 26, 2009 | 01:37 PM
pianoguy's Avatar
pianoguy
A lot of folks swear by The Right Stuff for the china walls - I had my engine guy use it when he put mine back together. I believe the bead should be run right up to the edge of the gasket.
Old Jul 26, 2009 | 01:41 PM
STL94LT1's Avatar
STL94LT1
I overlap mine just a bit.
Old Jul 26, 2009 | 04:34 PM
PLRX's Avatar
PLRX
Co-winner 2020 C4 of the Year - Modified
2017 C4 of Year
2016 C7 of Year Finalist
St. Jude Donor '09 thru '20
go as 1/2" high on the heads with the RTV. Ensure it is VERY CLEAN
To Intake manifold gaskets
