Power Seat Problems
Old Feb 14, 2002 | 11:26 PM
Shylor's Avatar
Shylor
Default Power Seat Problems Found!
I finally figured out what is causing all the C4 Power Seat problems! I took my grinding seat track apart today. The gearing is a combination of metal worm gears, metal gears and plastic gears. It's held in place by a plastic base inside the metal housing. On the end of the worm gears are plastic caps. There are 3 of them. Two of the caps on mine were cracked, allowing the worm gears to jump around and not making the connection with the gear it works with. If you look at both sides of the metal transmission portion of your seat tracks, you can see 3 small windows with white plastic in them. These are the caps to the worm gears. The metal housing hold them in place.
The plastic gears seem to work very well with the metal worm gears. I was surprised to find out that they were not the problem. I am hoping to be able to make the plastic end caps out of metal, thus correcting the problem. It seems like a very easy fix. Popping off the rivets of the metal housing was easy and re-riveting them should be as well.
[Modified by Shylor, 11:17 PM 2/14/2002]
Old Feb 14, 2002 | 11:44 PM
Shylor's Avatar
Shylor
Default Re: Power Seat Problems (Shylor)
Oh I forgot to tell you, my unit is a 96.
Old Feb 15, 2002 | 12:30 AM
EricVonHa's Avatar
EricVonHa
Default Re: Power Seat Problems Found! (Shylor)
I was curious about what was actually inside those suckers. I've got 2 d.o.a. seat racks at the moment. They both don't move in the fore and aft positions.
When you make those repair caps, make a couple extras, will ya? I'll send you some $$$. Thanks much. :yesnod:
Old Feb 15, 2002 | 01:05 AM
Shylor's Avatar
Shylor
Default Re: Power Seat Problems Found! (EricVonHa)
You bet! Shouldn't even have to take the track apart, just take out the rivets for the transmission housing, remove and replace caps, re-rivet...done. I'll let you know.
Old Feb 15, 2002 | 06:17 PM
Shylor's Avatar
Shylor
After more thinking about this, there is a plastic fram inside the metal housing that holds all the gears together. I'm thinking that should also be made in metal. I'll let you know how it goes!
Old Feb 15, 2002 | 06:20 PM
EricVonHa's Avatar
EricVonHa
Send me an e-mail to EricVonHa@aol.com when you get a chance. I tried finding your email in your profile... un-listed.
Old Feb 15, 2002 | 09:03 PM
emoshn's Avatar
emoshn
Same here on the email. dslater@polarnet.com
Old Feb 15, 2002 | 10:39 PM
Shylor's Avatar
Shylor
Default Re: Power Seat Problems Found! (emoshn)
I'm not sure what you guys want as I haven't even made the parts yet. If you want to discuss it we can do it here until I have things figured out. :D
To Power Seat Problems
