Could you help narrow this down???
Old Jul 28, 2009 | 05:04 PM
WW7's Avatar
WW7
Default Could you help narrow this down???
I have a engine miss when Im just cruising, not when Im accelerating. If I accelerate it runs smoothly, its only when Im either just running along at one speed , letting off the gas slowly,or at idle...I just replaced the egr and the O2 sensor,checked the fuel pressure and checked for vacuam leaks and it still does it..The plugs and wires are only a year old but tomorrow Im changing them hoping that fixes the problem. With it only doing it while going at a steady speed or at idle can you think of any other things it might be? Anything you can suggest as being the cause will be appreciated....WW
Old Jul 28, 2009 | 09:12 PM
Churchkey's Avatar
Churchkey
Had a similar problem on a 89 vert. Miss at cruise, full power at WOT. Had one injector that would not seat properly. Two cans of NAPA injection cleaner through the fuel rails solved the problem. This procedure requires specialized equipment.
Suggest reading the plugs when you remove them, if one or more show signs of running rich you may have a similar problem.
Old Jul 30, 2009 | 06:49 PM
WW7's Avatar
WW7
Well I didn't get very many answers to my question but I figured out the problem anyway, (By myself)..Anyhow I thought I would post what the problem ended up being so it may help someone with similar problems in the future..It turned out to be the coil, the wires in the coil somehow touched and burned each other causing a short that was only present at idle and when cruising, so I guess if you have a miss its a good idea to start at the plugs and work your way up to the distributor.I hooked it up to my Auto Xray 6000 and it showed no problems....WW
Old Jul 30, 2009 | 07:02 PM
farscape1a's Avatar
farscape1a
i'm actually having a similar problem. i'm missing and sputtering and stalling at idle, but at WOT, i've got full power for the most part. occasionally under hard acceleration, it suddenly falls on its face and then the SES light comes on. any ideas?
Old Jul 30, 2009 | 07:31 PM
pologreen1's Avatar
pologreen1
wow cool you found it, with no major damage as a result.
Old Jul 30, 2009 | 07:52 PM
-=Tom=-'s Avatar
-=Tom=-
That sounds like a bad o2 sensor. I just had nearly the same problem. My understanding is that the o2 sensor isn't in the loop at WOT which is why it runs fine then. I just changed the one on the driver's side since it was giving me erratic and low (4mv) readings when I had a laptop hooked up to the car yesterday.
Old Jul 30, 2009 | 07:54 PM
farscape1a's Avatar
farscape1a
what's the O2 sensor supposed to read? i never thought about that. i thought it might be electrical or throttle body related. i already pulled the throttle body and cleaned it as well as changing the PCV valve, but to no avail...
and what program are you running with what cable?
Old Jul 30, 2009 | 07:56 PM
WW7's Avatar
WW7
Actually, I found 2 other problems while looking for the answer to this problem..I found I had a bad EGR, and a bad O2 sensor. Its amazing it was running at all.....WW
Old Jul 30, 2009 | 08:01 PM
WW7's Avatar
WW7
Tom, On my scanner it shows the O2 sensor being used at all throttle openings. Farscape,It could be your EGR is stuck or sticking open,this is usually what goes bad on them..This will cause it to run bad at idle and midrange but at WOT the EGR cuts out and isn't used by the ECM...Just a guess....WW
Old Jul 30, 2009 | 08:06 PM
farscape1a's Avatar
farscape1a
Originally Posted by WW7
It could be your EGR is stuck or sticking open,this is usually what goes bad on them..This will cause it to run badly at idle and midrange but at WOT the EGR cuts out and isn't used by the ECM...Just a guess....WW
would it also cause the car to fail emissions testing? i just had it tested today and it failed from what the shop guy told me...
and i didn't mean to hijack your thread... you were just having a similar problem that i am having... thanks!
Old Jul 30, 2009 | 08:21 PM
WW7's Avatar
WW7
No Problem, Yes it will cause it to fail, as a matter of fact most of the guys on here will tell you if you have emissions testing in your state not to delete your EGR. Also the O2 sensor that Tom was talking about can cause it to fail . I replaced my O2 sensor yesterday because I was reading a Lean condition ( Block Learn was at 148 ) and it was dumping a ton of gas into the engine making it run Rich..After the O2 was replaced the Block Learn was down to 128 which is normal. I just noticed you have a 94 vette, I believe you have 2 - O2 sensors in your car....WW
Old Jul 30, 2009 | 08:28 PM
farscape1a's Avatar
farscape1a
No Problem, Yes it will cause it to fail, as a matter of fact most of the guys on here will tell you if you have emissions testing in your state not to delete your EGR. Also the O2 sensor that Tom was talking about can cause it to fail . I replaced my O2 sensor yesterday because it was causing a Lean condition ( Block Learn was at 148 ) and it was dumping a ton of gas into the engine making it run Rich..After the O2 was replaced the Block Learn was down to 128 which is normal. I just noticed you have a 94 vette, I believe you have 2 O2 sensors in your car....WW
i'll take a look into both the EGR valve and the O2 sensors then. i actually have a spare EGR valve from another project that i'll throw on just to see what happens. i also have heated O2 sensors that i'll have wired into the car.
now what would cause the car to fall on its face under hard acceleration and then cause it to throw a code? i haven't pulled the code yet, so i can't give that info unfortunately...
Old Jul 30, 2009 | 09:15 PM
farscape1a's Avatar
farscape1a
anyone?
Old Jul 31, 2009 | 08:36 AM
-=Tom=-'s Avatar
-=Tom=-
Yep it shows the o2 sensor working at all throttle openings because the o2 sensor never stops working but it's my understanding that it's not in the engine management loop at WOT. Thus you would see it working on any scanner but it's not being read. That's my understanding of it anyways and I could very well be wrong.
My issue was that the car idled rough, ran rich and stumbled under normal driving but worked fine at WOT. I replaced the fuel filter and pcv valve to no avail. Then saw the weird readings from the driver's side o2 sensor and replaced it and all my issues seem to be resolved.
Old Jul 31, 2009 | 10:31 AM
WW7's Avatar
WW7
Yep it shows the o2 sensor working at all throttle openings because the o2 sensor never stops working but it's my understanding that it's not in the engine management loop at WOT. Thus you would see it working on any scanner but it's not being read. That's my understanding of it anyways and I could very well be wrong..
You may very well be right, your car is much newer then my 89 and there are many differences in the electrical systems...WW
Old Jul 31, 2009 | 11:46 AM
-=Tom=-'s Avatar
-=Tom=-
Here's what I use:
http://www.ttspowersystems.com/DataMaster.html
and PCMComm from here:
http://carputing.tripod.com/9495LT1Edit.htm
as well as Tunercat from here:
http://www.tunercat.com/
Really for diagnostics PCMComm works perfectly well and is free. I only use Tunercat to reprogram the PCM.
I bought a USB to ALDL cable from somewhere online (I can't remember where) and hook that to the laptop. It's an awesome troubleshooting and diagnostics tool. The cable is only about 60.00 and the software is free so it's great to have. You can also do easy updates like removing the skip shift if you have a manual transmission, remove VATS if you have an issue with it, lower your temp for the fans to kick on, etc.
Old Jul 31, 2009 | 02:09 PM
farscape1a's Avatar
farscape1a
WW7, where would the O2 sensors be? thanks again!
Old Jul 31, 2009 | 03:03 PM
WW7's Avatar
WW7
One in each pipe between the exhaust manifold and the converter,should be screwed into a bung, wire running to each...WW
Old Jul 31, 2009 | 03:36 PM
farscape1a's Avatar
farscape1a
that's what i thought, i just wanted to confirm. thank you very much! i really appreciate it!
To Could you help narrow this down???
