How to fix burned-through floorpan?
As I was gutting the interior from my 91, I found that the passenger side corner, where the floorpan meets the trans tunnel as it widens for the bellhousing, was burned by the exhaust, in approximately a 1" diameter circle. It was not burned entirely through, but all that remained was fiber strands, no hard substance at all. The carpet padding overlying it was completely disintegrated. I never smelled anything burning, so this may have happened when the previous owner had the exhaust done, I have no way of knowing.
So, what to do? Obviously I need to patch the hole, but more importantly, I suppose I need to fabricate a heat shield? Or do I just have a muffler shop bend the pipe a little?
What should I use to patch the floor pan?
Thanks!
Andrew
Use either Epoxy resin or SMC resin. Fiberglass may lay down and harden, but it isn't the best choice and won't last from what all I've read. You'd only want to do the repair once.
I've used expoxy and it's seems to have stayed nice and bonded.Ditto on getting the pipe moved and some heat shielding in there.
Inside front left corner passenger side:
Outside:
I clean and degrease the floor pan on the outside and inside. Usually use carburator cleaner in spray or thinner. I let it dry perfectly.
I then apply some masking tape / duct tape or any tape you have at hand , to the outside of the broken plastic part. I try to apply small pieces to give the approximate shape of the floor pan.
Then from the inside. ( By now the carpet has been removed ). I apply cyanoacrilate glue ( this brand has worked great for me: http://www.zapglue.com/)
I let the SMC fibers soak for a little, also the tape.
THen apply another coat, soaking wet. I apply sodium bicarbonate ( baking soda ) and this will get wet with the cyanoacrilate glue making a reaction, you will see some fumes and vapor coming out.
I then blow off the bicarbonate that has not impregnated. Apply more glue and then more bicarbonate, blow it again. You get the idea. This will build a rock like material that can latter be shaped by sanding.
After you cover perfectly the hole and give it the shape you like. Then apply fiberglass and wet it with epoxy resin. You can use carbon fiber if you like.
Apply several coats of this combination until you give the part an adequate shape and thickness . The epoxy resin + fiberglass should extend beyond the hole.
This repair will seal perfectly and hold on very well giving structural rigidity to the part specially if you use carbon fiber.
If you have doubt send me a message to give you further instructions.
Good luck
Vacuum bag it if you can for the bottom, you can get away w/o bagging it on the inside, wet the glass in resin before you put it in place. Then tap all the air out of it.
Is this something that is usually covered by insurance? I had bumped the car a while back and planned on getting it painted. But figured I might just see about making a claim so I'm only out my deductible to get it painted instead of thousands. So, I might could just add this on to that claim.
http://composite.about.com/od/aboutc...l/aa000109.htm
http://www.bertram31.com/proj/tips/vaccuum.htm
You can get by w/o it, it's a lot easier with it.
Here's the boat that I'm working on
I used fiberglass and it has held up well since the year or 2 since i did it.
The most important thing i learned and would pass on to you is: USE the 50/50 mix style fiberglass, not the big tub of goop you mix with an ounce of activator!!
its a million times easier and you wont have half the clean up! Good luck!
And when you did yours, did you do it on the inside, outside, or both?
http://forums.corvetteforum.com/c4-t...or-repair.html
Got any idea how much a shop normally charges to do this if the carpet is out of the way?
So, what else can one do? Just tape up the hole from the bottom?
I was thinking of fixing it on the inside as it would be easier to do unlike trying to do it under the car with no room. And I'd be able to make sure the inside was sealed off from the outside.
And did you drill out any loose pieces? On the hole in mine, I pushed on it and could feel loose pieces. I have heard of people saying to leave the loose pieces there and I've heard you need to remove all the loose pieces.
What your really after is keep the material all pressed together while the resin cures.
