Brake problem 1992
Old Jul 30, 2009 | 08:04 AM
giant76's Avatar
giant76
3rd Gear
Default Brake problem 1992
I installed new rear brake pads on 1992 vette and then the brake light stayed on. I drove it and worked the brakes and the light went off. Now the brakes front and rear are dragging terribly. It is like I have my foot on the brake pedal all the time. Do I need to bleed the brakes if so what is the correct order? The brakes were dragging some before the new rear pads.
Old Jul 30, 2009 | 09:33 AM
RAP-Corvette's Avatar
RAP-Corvette
2nd Gear
Sounds similar to a problem I had recently. Ended up having to replace the master cylinder. I found a pretty good price on one here:
http://tinyurl.com/mjmdtc
Not confident that this is the problem though.
Hope this helps.
Old Jul 30, 2009 | 09:40 AM
94z07fx3's Avatar
94z07fx3
"what is the correct order?" RR LR RF LF
My list of suspects would include:
Failed flex hose(s) acting like one way valve
Parking brake not fully disengaged
MC return spring binding on goo or particles in MC
When was the last fluid flush?
Old Jul 30, 2009 | 10:42 AM
jaa1992's Avatar
jaa1992
From: Life is just one big track event. Everything before and after is prep and warm-up and cool-down laps
Cruise-In III Veteran
Cruise-In IV Veteran
St. Jude Donor '12
I'm going to guess the brake fluid has not been flushed at all.
You may wind up needing MC, brake lines, and rebuilt calipers to get it back to normal.
Please, please, please everyone flush your brake fluid every couple years!
Old Jul 30, 2009 | 04:04 PM
L71Maynard's Avatar
L71Maynard
If you haven't already, check you fluid level. When putting in new pads it will raise the fluid level since the caliper pistons are compressed further.
I agree with what has been said, it would not be a bad idea to replace the fluid.
Dave
Old Aug 9, 2009 | 01:07 PM
giant76's Avatar
giant76
3rd Gear
You got it - replaced master cylinder and flushed brake system. Thanks
To Brake problem 1992
