Rotor replacement
Old Jul 30, 2009 | 09:45 AM
lt4obsesses's Avatar
lt4obsesses
Default Rotor replacement
I am getting ready to replace the rotors on the LT4. I bought a set from a forum member off a 3500 mi LT4. They're in perfect shape and ready for install.
As I understand, it's pretty straight forward. Once the wheel is off, remove the two caliper bracket bolts on the knuckle, clean out the threads, put on the rotors and tighten them down, I believe 137 ft lbs.
The recommendation is to replace the bolts w/ new ones from Chevrolet which have thread adhesive on them. But have read that cleaning the old ones and using blue thread locker is good enough.
Is there anything I'm missing or should know about? I want this to be right the first time as this is my only car and won't be able to make a "parts run" and also, well, brakes are a good thing have working properly.
Old Jul 30, 2009 | 09:48 AM
PLRX's Avatar
PLRX
Co-winner 2020 C4 of the Year - Modified
2017 C4 of Year
2016 C7 of Year Finalist
St. Jude Donor '09 thru '20
If the bolts' thread is in good shape, re-use them (i did). I used red thread lock.
Check the FSM, I think they tight to 156 ft-lbs
94z07fx3's Avatar
94z07fx3
You've got it! Don't be shocked if you have to use a large cheater bar to break them (caliper mounting bolts) loose the first time.
The torque is lower for the rears tho I think it's in the 80's range.
Recheck the caliper mounting bolts for proper torque at each oil change and lube. It only takes a minute.
Old Jul 30, 2009 | 09:56 AM
runner140*'s Avatar
runner140*
I had to use a wrench with an 18" pipe for leverage to break the bolts free.
Old Jul 30, 2009 | 09:57 AM
pianoguy's Avatar
pianoguy
I had fun with the rears, as I couldn't decipher the crayon drawings in the FSM to figure out how to properly slacken the parking brake cable.
Old Jul 30, 2009 | 10:02 AM
lt4obsesses
Thanks guys. I have a shiney big daddy breaker bar so those bolts don't stand a chance Rechecking the torque settings and good to go.
Old Jul 30, 2009 | 10:21 AM
Sidney004's Avatar
Sidney004
Use the blue loctite. Red is stronger (permanent) and will make it very hard to remove in the future. I replace rotors very often as mine is track driven and crack frequently; I reuse the bolts and never use Loctite(but I examine the bolts regularly.)
Old Jul 30, 2009 | 10:24 AM
jrp's Avatar
jrp
I didn't need a breaker bar for mine, but I do have a flex-head ratchet with a slightly longer handle. Other than on the exhaust, I really haven't had trouble with any of the typically stubborn fasteners yet.
If I remember correctly, the parking brake cable isn't slackened, but the self-adjuster is locked at the handle. It doesn't seem to be a big deal for this job anyway, in my experience. I've had the rear rotors on & off at least twice without fussing with it, and the parking brake still holds well on my sloped driveway. Just leave the cable attached to the caliper. I will probably follow the FSM in this regard when I remove the calipers entirely for a rebuild & repaint. (One of these days... some of you may have seen me say that a long time ago. :o)
I actually went to a local dealer service department to ask about re-use of the fasteners, and that's what they do. If it's good enough for them with the risk of litigation, then I'm OK with it too. I use the blue loctite.
Make sure you have all the right socket sizes. The fronts were larger than in my set, and one of the rears is an allen head. Luckily, we have another car, so acquiring tools as I go is a mere annoyance.
Old Jul 30, 2009 | 10:29 AM
jaa1992's Avatar
jaa1992
From: Life is just one big track event. Everything before and after is prep and warm-up and cool-down laps
Cruise-In III Veteran
Cruise-In IV Veteran
St. Jude Donor '12
Mine are off and on so much that locktite would be a waste. I go a max of 2 events before they are off and on again.
FOr street car - USE THE BLUE!
Old Jul 30, 2009 | 08:21 PM
joe wilson's Avatar
joe wilson
I agree, don't use the Red Loctite on anything you need to remove in the future. I is very damaging to the threads. I keep it handy for bolts that keep coming loose. It puts an end to that!
Old Jul 30, 2009 | 08:59 PM
n1kki6's Avatar
n1kki6
I might be in the minority, but I just did my rotors, pulled the wheels, calipers and rotors and just put it all back on, tighten everything down and go.
Old Jul 31, 2009 | 12:39 AM
lt4obsesses
Yeah, so I get the "new" rotor on. Get the caliper back on. Give it a spin to test. It goes about 1/3 turn and comes to screaching halt. Okay, so perhaps I need to push the piston back to reset the clearance, right. Well I keep the bracket on, and decide to put the lugs on all five, tighten them by hand plus about 1/4. Give the rotor a spin and this thing looks like one of those kiddie rides at the carnival. All kinds of warp in this S.O.B.
Thought it might be dirt or debris, or install issue as it didn't want to come off at first. But the old one went back on w/o problem.
Oh well, I really wanted slotted/drilled rotors anyway.
Old Jul 31, 2009 | 10:37 AM
theadmiral94's Avatar
theadmiral94
From: 1994 LT1 Coupe 6-speed with FX3 & 2000 LS1 Vert 6-Speed with F45 Hunterdon County, NJ
Sorry, but on torque,
There was a long post a few years ago, including lots of testing which confirmed the torque in the FSM is INCORRECT and too high (causing stretching and breakage).
The conclusion was that 137 ft lb is max front caliper mounting bolt torque.
Also regarding the re-use of the bolts, one concern is that IF the bolts had been previously torqued to the FSM torque amount, reuse (even with blue locktite) could be dangerous.
Given a lack of knowledge of what the PO has done, would recommend buying new bolts this time, but if needed, reuse later on -- is it really worth a few dollars for the damage (or death) which could result otherwise if the caliper bracket where to come loose !!
P.S. if you were to disagree with the old post of the torque being too high in the FSM -- and want to believe the FSM is correct, then by default you would also need to believe the FSM specifing to REPLACE the bolts is ALSO correct -- as the two things are directly related...
Old Jul 31, 2009 | 10:54 AM
Sidney004's Avatar
Sidney004
The lug nuts have to be tightened onto the rotor for the "spin test" or to properly seat the pads during their installation. I very much doubt the rotors are warped; that a wives tale. Put it back together, tighten the lugnuts, give the brakes a stab,do the spin test and repost the outcome.
Old Jul 31, 2009 | 04:25 PM
lt4obsesses
Yeah I knew about the 137ft lbs. As far as the bolts, I bought the car w/ 24K on the clock and at my first brake pad replacement I was positive they were the original pads I am also sure the caliper braket hasn't been disturbed since new. The bolts and threads looked brand new.
Old Jul 31, 2009 | 04:30 PM
lt4obsesses
I may give it another try this evening. I was thinking I might be a bit hasty in writing these things off. But I am pretty carefull and thorough when it comes to this kind of stuff. What I don't know is how or where these rotors were stored before he decided to sell them. If they were leaned up against a wall or in a non climate controlled area for any considerable amount of time, yes they could warp.
Old Aug 1, 2009 | 01:29 AM
Arkybill's Avatar
Arkybill
Non climate controlled area? How about the 1000s of vettes parked outside, North, South, reckon they sit thru some "non climate controlled areas"?
Take your old rotors and get them turned, cost $4 here (arkansas) then they will be true.
Good start.
bill
To Rotor replacement
Old Aug 1, 2009 | 10:27 AM
theadmiral94
Presume you know this but just in case...
be sure to wire-brush the center spindle and area around the lugs and the back of the rotor and the back of the rim (and can always 'index' (rotate the rotor 1/2 way around on the lugs) to try and reduce the runout--
I recently did this on our 2000 TA and was able to reduce run-out and pedal pulsation (even though they 'looked' clean).
Also, the metal of the rotors is soft enough that you cannot get the 100 ft lb of torque required to properly set the rotor -- best way is with the wheel installed, but then you can't get to the outer edge of the rotor with a run-out gauge, so ideal is with a spacer plate over the lug bolts or maybe just the center of a rim or just do the back-side of the rotor...
Old Aug 1, 2009 | 01:23 PM
Aurora40's Avatar
Aurora40
If you have stock sliding calipers and you seated the pistons fully, I would think the rotors would have to be insanely warped to drag on used pads...
That said, I'm not sure I'd put used rotors on a car unless in a pinch.
Old Aug 2, 2009 | 02:11 AM
lt4obsesses
Good start.
bill
Thanks for your input Bill. Believe me the first thing I wanted to do was turn the old rotors, but they're beyond that. But thanks for the suggestion. When I mentioned "climate control" I was refering to the rotors being off the car and possibly not laying flat. Changing temps and humidity could cause warpage if in that position long enough. But thanks again for trying to cheer me up.
