Speedo issue
Old Aug 23, 2009 | 05:28 PM
96GS#007's Avatar
96GS#007
Thought I'd close this one out. If you read thru the posts you'll see everything I did. The final attempt involved replacing the new (albeit AutoZone cheap) VSS with a new VSS from AC Delco.
After roughly 60 miles of driving, including many full throttle runs thru a couple gears, all appears to be normal. The speedo doesn't jump around, drop to 0mph, or shoot to 220mph.
Now I can finish my part throttle tuning and get down to Tom Wongs place for WOT
Old Aug 23, 2009 | 09:12 PM
No Go's Avatar
No Go
So there really is something to that motto, "Keep your GM, all GM..." Nah...just bad luck getting a bad part at the local store.
Happy to hear it is back on progress-let us here some dyno numbers!
Old Aug 24, 2009 | 04:02 PM
C4DC's Avatar
C4DC
St. Jude Donor '06
I got my new VSS from rockauto. I'm pretty sure that it wasn't a Delco part. Seem kind of odd that it does the same thing with the old/new parts in both of our cases. Maybe there is a slightly different characteristic in the OEM. I'll wait a while before springing for another one to see if your problem pops up again.
