Converting Crossfire to TPI
Old Aug 1, 2009 | 11:27 AM
eilax053's Avatar
eilax053
Default Converting Crossfire to TPI
What would be needed for me to convert my crossfire to a TPI
Old Aug 1, 2009 | 12:09 PM
BobRR3's Avatar
BobRR3
I saw this done on Two Guys garrage on the Speed channel. ( formerlly shadetree mechanics) They had a permade wiring harness and everything you need. go to the website and see if you can find previous show listings.
Old Aug 2, 2009 | 11:25 AM
ray1979's Avatar
ray1979
I just converted mine to a First TPI. You will need the TPI and all sensors the computer and wire harness. Acc brackets from an 85 Vette
a way to route the air filter.
Old Aug 2, 2009 | 01:22 PM
qws's Avatar
qws
A complete waste of money for a very minor gain. TPI also has its restrictions.
For better information than your gonna get here go to
http://www.crossfire.homeip.net/
A lot of ways out there to get better gains for less money.
Old Aug 2, 2009 | 05:27 PM
ray1979's Avatar
ray1979
I do not know if i would call it a waste of money. My car runs real well now. It also ran pretty good as a cross fire but the first is a nice improvement.
Old Aug 2, 2009 | 06:08 PM
qws's Avatar
qws
Assuming more HP is the ultimate goal here for the OP from TPI... then it is.
For a lousy hp gain of 25 hp the OP will have to invest how much?
You can port the CFI intake yourself for zero dollars and have a higher gain than you can achieve from the conversion.
CFI intake below.... left side ported....right side stock. Let the intake breathe and you will have better results than the conversion to TPI
Old Aug 2, 2009 | 07:51 PM
xrcrx's Avatar
xrcrx
I had my CFI into the 13's on a 130k mile engine.
Old Aug 3, 2009 | 09:16 PM
eilax053's Avatar
eilax053
hmmm... maybe i will just port the intake. What about the heads. Are they the same way?
Old Aug 3, 2009 | 09:29 PM
qws's Avatar
qws
IMO, I think that would be a better route to go if your looking for a hp gain.
The heads are junk.
What are your goals? Start there
Old Aug 3, 2009 | 10:32 PM
383vett's Avatar
383vett
Here's a converted '84. A waste of money?
Old Aug 3, 2009 | 10:39 PM
qws's Avatar
qws
Did you read my post completely?
Convert a Crossfire to TPI...YES
Your not comparing Apples to Apples here.
But hey you got to post a nice pic
Old Aug 3, 2009 | 10:40 PM
CorvetteMike2024's Avatar
CorvetteMike2024
Corvette Enthusiast
Default vette
Nice 84. I set your pic of the 84 as my desktop.
Corvette Mike
Old Aug 3, 2009 | 10:55 PM
JackDidley's Avatar
JackDidley
You just need to select the right tpi. If you install a bigger cam, Miniram would be my pick. Lots of choices out there.
Old Aug 3, 2009 | 11:26 PM
383vett's Avatar
383vett
Corvette Mike
Thanks Mike.
Old Aug 4, 2009 | 03:03 PM
eilax053's Avatar
eilax053
The heads are junk.
Its my daily driver so no real high goals. Im gonna just port it out and leave it at that for now.Thanks for all your help guys
Old Aug 4, 2009 | 05:21 PM
pologreen1's Avatar
pologreen1
port the hell out of it, and be done, until you actually are willing to put about 4k in to heads cam, etc. etc
Old Aug 4, 2009 | 05:41 PM
87 Ragtop's Avatar
87 Ragtop
CI 3-4-5-6-7-8-9-10-11 Vet
CI X Blind Auto-X Champ
I haven't been there in a long time but there are a great group over there for the Crossfire. I had 2 of them and am still kind of sentimental to them. The L98 is definitely better. But the Crossfire is definitely more unique as it was the only year engine in both the C3 and the C4. Now that I have a C5, the LS1 is a big step up from that But I still love the L98 in the C4. Now the 305 TPI in my Firebird... well I think that could use an upgrade to an LS1. If I don't do that, I'll still keep the TPI look with a bigger motor.... someday $$$
To Converting Crossfire to TPI
Old Aug 4, 2009 | 06:04 PM
Rohn's Avatar
Rohn
1. Buy a single plane EFI manifold(proproducts or Edelbrock or Holley)
2. Purchase a 4 barell TB unit(sequential nice) or a GM 7.4L TBI unit and remove the pod and injectors.
4. Buy rails and mod fuel lines.
5. Buy EBL-ECU (dynamicefi.com)
Might just fit under stock hood. I think it will.
Dont bother unless you are planning on modifying engine.
Old Aug 5, 2009 | 10:49 AM
85vette-84vette's Avatar
85vette-84vette
You could just order the "renegade intake manifold" from a company called Dynamic Crossfire Solutions. They have designed and intake manifold just for the crossfire engine. There is a preorder going on right now and the intake will be ready and shipped out at the end of august or early september. It will give you just over 40HP at the fly wheel and 33HP at the rear wheels and 18 lb/ft of torque at the rear wheels. This is a proven intake and sometimes with the ported intake some people get good results and some people lose power on the bottem end and not much gain on the top end.
Old Aug 5, 2009 | 02:03 PM
jhammons01's Avatar
jhammons01
The heads are junk.
What does that mean exactly. Not questioning, I've just never heard a clear explanation.
