Metric or Standard
Old Aug 1, 2009 | 09:53 PM
ZakVette93's Avatar
ZakVette93
7th Gear
Default Metric or Standard
I have on order a set of head gaskets now I need to know if the head bolts are metric or not as I will be replacing them.
I will be doing this job myself as I have the time but no job thanks to the recession oh also very little money to spend. Good thing the other half still has an income.
The car is a 1993
Any help is well come.
Old Aug 1, 2009 | 09:56 PM
STL94LT1's Avatar
STL94LT1
The head bolts are standard.
Old Aug 1, 2009 | 10:31 PM
Mojave's Avatar
Mojave
For an LT1, a good rule to remember is: if the bolt threads into the block or heads, it is SAE. If it threads into the intake, it is metric. The intake to head bolts thread into the heads, so they are SAE, while the throttle body bolts are Metric.
The bottom end of an LT1 is all straight SBC, so it is all SAE threads.
Old Aug 2, 2009 | 10:46 AM
jaa1992's Avatar
jaa1992
From: Life is just one big track event. Everything before and after is prep and warm-up and cool-down laps
Cruise-In III Veteran
Cruise-In IV Veteran
St. Jude Donor '12
Make sure you buy new head bolts!!!!
And use permatex thread sealer on the bolts.
To Metric or Standard
