Brakes on 91 vette locking? Need Help Fast!
Old Feb 15, 2002 | 05:37 PM
krivera's Avatar
krivera
Default Brakes on 91 vette locking? Need Help Fast!
Needing help on my 1991 corvette my brakes are locking up when my car gets hot and i have replaced almost everything i have replaced....Booster, master cylinder, rotor, pads, bleeded brakes with all new fluid in lines. But i talked to a brake place and they said it cold be the ABS system?
Example...start car in morning, let it warm up 5 min... start to drive for about 3 miles works fine.....ABS kicks on (little late) then my problems start...i have to floor the car to get it to move and then the brakes feel hard as can be and then i can smell the pads just smoking?
This issue is new to me and all my friends that have corvettes? Maybe someone accross the united states can help me!
Thanks Kevin Rivera
Denver Colorado!
Old Feb 15, 2002 | 06:25 PM
bogus's Avatar
bogus
Default Re: Brakes on 91 vette locking? Need Help Fast! (krivera)
wow... this could be a bad speed sensor somewhere sending bad info to the ABS computer.
try pulling the fuse on the ABS system and see if it continues. At least then you will know the cause...
Old Feb 15, 2002 | 06:45 PM
IBEAM700's Avatar
IBEAM700
From: Looks like I picked the wrong week to stop sniffin glue Orlando
Default Re: Brakes on 91 vette locking? Need Help Fast! (bogus)
bogus is right on the money. Pull the ABS fuse and reset the computer. sure sounds like ABS to me. :chevy
Old Feb 17, 2002 | 03:18 PM
C4396roadster's Avatar
C4396roadster
I would have the whole sys checked out by a specialist because there are way too many sensors to do trial and error which can cost more $ that could be spent somewhere else productive like speed gear
Old Feb 17, 2002 | 04:46 PM
BBA's Avatar
BBA
You have a bad brake hose. Replace all of them.
The inside of the hoses deteriorate and block the fluid from returning to relieve the pressure...hence the caliper locks and can even burn up the pad/caliper/rotor.
Old Feb 17, 2002 | 07:53 PM
Goody's Avatar
Goody
Default Re: Brakes on 91 vette locking? Need Help Fast! (BBA)
Make sure emergency brake isn't sticking.
Old Feb 17, 2002 | 10:01 PM
Da-Cajun's Avatar
Da-Cajun
Default Re: Brakes on 91 vette locking? Need Help Fast! (Goody)
All of the above replys are something you want to check out. There is a little rod that goes from your brake booster to the master cylinder. It is adjustable You did say that you have replaced the master cylinder and brake booster. Has this rod been replaced also? Back it down a turn to a turn and a half. Test drive the car and see if this eliminates your problem. Good luck!
[Modified by Da-Cajun, 5:27 AM 2/18/2002]
Old Feb 17, 2002 | 11:08 PM
A's Avatar
A
I had the same problem with my Camaro a while back. I'll put my money on the hoses :yesnod:
To Brakes on 91 vette locking? Need Help Fast!
