Bench test a C4 brake booster?
Can this, or any future used boosters be easily bench tested?
BTW this was a 94 plastic model booster.
Corvette Mike
Read the FSM before trying this for warnings (seem to remember something), but you might then be able to depress the shaft (which connects to the brake pedal) to verify no real loss of vacume (the depression should open up the back side of the diaphram to outside air, while closing off the vacume to the back side of the diaphram at the same time, sucking in the shaft, and not allowing any vacume to escape to back side of the brake booster.
Could be the booster shell (which when heated-up, seals a leak), but should hear a leak when cold and presume you've listened and not heard it (start, run for only a minute or so, turn off and listen).
Have you checked the vacume level at cold idle? Should be at least 15-20 hg.
If not, could be a broken vacume line, bad vacume 'check valve' (for AC controls), old PCV valve, intake manifold leak, throttle-body leak or butter-fly carbonned-up, or brake-booster's vacume hose routed to the wrong connector.
