Stalling When Coming to a Stop and Lumpy Idle
Old Aug 2, 2009 | 07:32 PM
infamous's Avatar
infamous
Default Stalling When Coming to a Stop and Lumpy Idle
My 1994 LT1 383 had stalled on my twice last week when coming to a stop, and it sometimes has a lumpy/bouncing idle. I checked a few older posts on here and decided to do some work today.
Today I changed the PCV valve, replaced two vacuum lines that were probably original, cleaned out the MAF sensor, cleaned the IAC valve, and made sure my throttle body was closing all the way. I started the car and let it run for a bit and it seemed fine, holding a constant idle speed. I'll see if it stalls on me during my drive to work tomorrow.
Old Aug 2, 2009 | 07:38 PM
pologreen1's Avatar
pologreen1
is it worse when holding the brake, or better in N than drive while brake, because most times this is a vac leak.
Old Aug 2, 2009 | 07:58 PM
farscape1a's Avatar
farscape1a
i'm having the same exact problem, but i have a stock LT-1. not a 383. to the OP, when you hammer down on the loud pedal, do you get full power? i do, but intermittently it falls on its face and the SES light comes on. i haven't pulled the codes yet though... i think i may have narrowed it down to the O2 sensors, or maybe the EGR valve. i have to look into it further before i start pouring money at it. i'm probably going to give it to the vette doctors in amityville to diagnose because i just don't want to be bothered at this point. i just want it to run right...
Old Aug 3, 2009 | 06:01 PM
infamous's Avatar
infamous
I haven't gotten to drive the car since I posted (looks like rain soon, so I won't get to drive it today or tomorrow either because of more rain), but it was better in Neutral than when the brake was on (car is an auto). When it shut off the second time I was going slowly through a turn in the neighborhood and had to go from D to N, crank the engine while fighting the turn with no power steering or power brakes, tip in a very little bit to the throttle, then go back to D. Other than that the car is great...just two recent stalls.
I'm hoping the two vacuum lines I changed and the cleaning of the MAF resolved this.
To the previous poster: I have no loss of power during large throttle demands, and the last owner deleted the EGR (I noticed when I was changing the PCV valve). The idiot light hasn't turned on yet either, other than the "check gages" light when the engine died.
Old Aug 4, 2009 | 06:10 AM
mseven's Avatar
mseven
Originally Posted by infamous
My 1994 LT1 383 had stalled on my twice last week when coming to a stop, and it sometimes has a lumpy/bouncing idle. I checked a few older posts on here and decided to do some work today. Today I changed the PCV valve, replaced two vacuum lines that were probably original, cleaned out the MAF sensor, cleaned the IAC valve, and made sure my throttle body was closing all the way. I started the car and let it run for a bit and it seemed fine, holding a constant idle speed. I'll see if it stalls on me during my drive to work tomorrow.
If everything mechanically is correct I would be looking at the tune (ecm). Do you have a way to run a scan (live data acquisition)?
Old Aug 5, 2009 | 09:49 PM
infamous's Avatar
infamous
I don't have any tools to record data on the vehicle. The vehicle was tuned by a local speed shop, but that was done with the previous owner.
I found another issue when I looked at the motor last night...I'm going to make a different thread for that one though.
Thanks for the responses.
To Stalling When Coming to a Stop and Lumpy Idle
