Engine quits, need help on 86
Unfortunately, it comes out the bottom, but it's not that easy to recognize for a first timer.
If you remove the plastic piece over the passenger's footwell. you look up, and it will be there with the connectors pointing down. There are a couple bolt/screws holding it in to a plastic box. You remove the connectors, then the two bolts, then slide it through all the other wiring, vacuum tubes and plastic stuff and it comes out in your hand.
