Leaky LT1 Intake Manifold Question
Old Mar 1, 2002 | 05:28 PM
Goody's Avatar
Goody
Default Re: Leaky LT1 Intake Manifold Question (Glock'94)
Sorry to take so long responding back. Yes, I just replaced the gaskets and that was that. Cleaned stuff up since I had it off anyway. Little too late to say all this, but at least you'll have piece of mind. :)
Oh yeah, the watery exhaust is just the condensation. A little steam looking stuff coming out for a while is normal as well. Going from hot to cold makes that metal attract moisture. Which is why a muffler will rust from within more than out. Also, I think that this is why you are supposed to change the oil ever 3 months or 3K miles....the 3 months of building up water in the oil. Especially if you only drive occasionally.
[Modified by Goody, 3:33 PM 3/1/2002]
Old Mar 4, 2002 | 08:03 PM
Mez's Avatar
Mez
From: Austin, Singapore, Kuala Lumpur, Houston, Dallas, Hong Kong, Elgin, etc.. Texas
Default Re: Leaky LT1 Intake Manifold Question (Goody)
Coolant coming off the back of the heads on the LT1 could be from loose coolant return tubes. These thread into the back of the heads and are there to vent steam back to the radiator on the reverse cooling system. They are on only the LT1 and LT4's. Kind of hard to see--use a mirror if necessary.
Check the banjo bolts and tighten if necessary. If this still leaking, the seals/washers may be bad.
Old Mar 5, 2002 | 01:58 PM
John Row's Avatar
John Row
Default Re: Leaky LT1 Intake Manifold Question (Torre)
I think you'll find that most job time estimates on the forum are only actual wrench in hand time. It doesn't count the time to clean, prep, jack, figure out "how the heck do I get a wrench on that" time or the "another trip to the parts store for the plastic connector I just snapped" time or the "trip to the tool store for that special tool to get that one d#*m bolt off" time.
My rule of thumb, if noone says it will take xxx hours, then it's a trip to the shop to have an expert fix it.
Cheers,
Old Oct 26, 2011 | 12:14 AM
brioneschevybelair's Avatar
brioneschevybelair
94 LT1 swap less then 50 milesI got water coming out the radator then drops of water on left header I remove the engine am sure it was the head gaskets drain the oil it had water but Question is on vent tube what size are the two bolts tryed a 5/8 and 15 metric the 15 is fit loose a 14 is too small ??
Old Oct 29, 2011 | 09:02 PM
ChrisLT1conv's Avatar
ChrisLT1conv
Maybe 9/16's
Old Oct 30, 2011 | 10:32 AM
brioneschevybelair
Default LT 1 Vent tube bolts
I finaly was able to remove the vent tube bolts I had tryed 15 metric wrench it started striping the bolts I used a 15metric socket just go slow and they came off, the rubber sealing washer looks like it toast now I dont know if you can get new ones ?
Old Oct 30, 2011 | 12:12 PM
STL94LT1's Avatar
STL94LT1
Try AutoZone in the help section.
Old Oct 30, 2011 | 03:51 PM
desertmike1's Avatar
desertmike1
these banjo bolts tend to "crud up" clean-em good...
here is a good replacement seal from NAPA.
the seal fits like a glove, oil it up when you install it..
Old Oct 31, 2011 | 10:51 AM
rickneworleansla's Avatar
rickneworleansla
I just read this whole thing before realizing it was a 9 year old thread.
Old Oct 31, 2011 | 12:15 PM
drmrman's Avatar
drmrman
Edit.
Old Oct 31, 2011 | 12:50 PM
brioneschevybelair
this waa Oct 30,2011 date
Old Nov 2, 2011 | 09:58 PM
brioneschevybelair
Nov 2 2011 I was abel to get the vent tube sealwashers at Napa just in case some one should need them later
