C4 rear diff ratio?
Old Aug 5, 2009 | 01:15 PM
VET4JDC's Avatar
VET4JDC
Default C4 rear diff ratio?
I'm posting this for a friend with a C4...can anyone help?
In researching my '96 LT4 coupe I have found several referals to a G92 Perf Rear Ratio but I have never been able to determine what the ratio is. Does anyone know?
Old Aug 5, 2009 | 01:28 PM
Trebor's Avatar
Trebor
I think this is a GM mystery. I have only seen the G92 RPO referenced as a "performance axle ratio".
I own a '96 CE LT4 with RPO GM3 Axle, Rear, 3.45 Ratio
Interesting if someone has an official answer.
Trebor
jhammons01's Avatar
jhammons01
If all else fails, it is etched into the bottom of the housing. Lift it up a little and slide under there...the ratio that they installed in the housing will be hand etched.
Of course you could look at the RPO codes located under the rear storage bin.
Old Aug 5, 2009 | 01:41 PM
Shrek's Avatar
Shrek
There should be a second G code to match one these rarios.
•G44 - Rear axle 3.07 ratio
•G87 - Ring gear 8.50 inch
•G92 - Rear axle performance ratio
•GH0 - Rear axle 3.54 ratio
•GM1 - Rear axle 2.59 ratio
•GM3 - Rear axle 3.45 ratio
•GT7 - Rear axle 3.33 ratio
•GU2 - Rear axle 2.73 ratio
•GW4 - Rear axle 3.31 ratio
EDIT: I got that info Here
Old Aug 5, 2009 | 02:38 PM
LT4 F45's Avatar
LT4 F45
LT4 6 speed = 3.45
Old Aug 5, 2009 | 02:49 PM
Mrs. glass car's Avatar
Mrs. glass car
Originally Posted by fast red 87 vette
LT4 6 speed = 3.45
All 96 manual transmissions are LT-4 engines and 3:45 axle ratio.
Old Aug 5, 2009 | 04:44 PM
Jonnymac's Avatar
Jonnymac
St. Jude Donor '08
G92=3.07 for the automatics only.
Old Aug 5, 2009 | 05:17 PM
PLRX's Avatar
PLRX
Co-winner 2020 C4 of the Year - Modified
2017 C4 of Year
2016 C7 of Year Finalist
St. Jude Donor '09 thru '20
x5
Old Aug 5, 2009 | 05:20 PM
rodj's Avatar
rodj
It means the car is fitted with the optional ratio that was available for that year; it is not a "particular " ratio.In most cases the ratio is lower so it is a "performance ratio
Old Aug 5, 2009 | 05:26 PM
LT4BUD's Avatar
LT4BUD
no factory options for LT4....all LT4 cars came with 3.45 ratio
Old Aug 5, 2009 | 07:05 PM
Blue 92's Avatar
Blue 92
CI 3-4, 8-9-10 Veteran
St. Jude Donor '06-'08-'10
There will be two RPO codes.
One is the G92 and tells you that it has the Perf Rear Ratio, the other tells you what that ratio is.
Old Aug 5, 2009 | 08:28 PM
JAKE's Avatar
JAKE
Yep, my 96 LT1 RPO code sticker shows G92 and G44 (3.07)
Jake
West Point ROCKS!
Old Feb 22, 2022 | 12:43 PM
eac1965's Avatar
eac1965
1st Gear
Jake
West Point ROCKS!
Is it a D36 or D44? Looking at a rear set up, VIN says its a manual with 3.07 performance gear set, but the pictures wrecking yard sent is of a D36. Did they ever put D36 in a manual car?
Old Feb 22, 2022 | 01:05 PM
WVZR-1's Avatar
WVZR-1
1984 all builds were D36!!!
What is the VIN of the car that brought you here to post? A snapshot of the rear that the 'yard' provided?
Old Jan 6, 2025 | 03:28 PM
Big_Philly94’Vette's Avatar
Big_Philly94’Vette
What ratio is the Rear Axle Performance Ratio? Thank you
Old Jan 6, 2025 | 08:55 PM
Big_Philly94’Vette
Thank you and it says on the build sheet Performance Axle Ratio but, it’s an automatic. On the build code sheet on the center console it states G44 and then G92.
Old Jan 6, 2025 | 09:30 PM
WVZR-1's Avatar
WVZR-1
Pretty simple and straight forward but you keep finding, posting to all of these very old threads. Your car G92/G44, A4 is 3.07.
There's many RPO deciphering apps out there and .pdf from many vendors including GM/ACD.
To C4 rear diff ratio?
