Zmax
Old Aug 6, 2009 | 02:44 PM
Shimy86's Avatar
Shimy86
Default Zmax
Anyone try this stuff??? Any thoughts
Old Aug 6, 2009 | 02:59 PM
Bobwhite85's Avatar
Bobwhite85
I was going to try it once i get my engine together. I will be watching to see the opinions are on this
Old Aug 6, 2009 | 03:16 PM
CAJUN C4's Avatar
CAJUN C4
Do You Really Think That Carol Shelby Would Ever Lie About Something??? LOL
Seriously, I don't know..Supposed to Adhere to Metal Surfaces or Something?
Old Aug 6, 2009 | 03:52 PM
PLRX's Avatar
PLRX
Co-winner 2020 C4 of the Year - Modified
2017 C4 of Year
2016 C7 of Year Finalist
St. Jude Donor '09 thru '20
STOP
I tried this on my 95 4 years ago. It created a disaster all along the oil pan gasket and front plate seals. I had the biggest oil leak in my history.
I drained the new oil, put new oil and ran the Vette until the oil reached 300 F and changed the oil again.
Screw ZMAX, I call the 800 number and insulted them. Carol Shelby can suck on this one too.
Old Aug 6, 2009 | 04:14 PM
bomar76's Avatar
bomar76
That garbage has been proven to actually HARM engines.
Been sued by the FTC.
Here is an excerpt from the FTC site:
"According to the FTC, the CRC L38 test is a standard auto industry tool to measure the bearing corrosion protection properties of motor oils. In February/March 1997, an independent laboratory performed two CRC L38 tests of zMax for Speedway and Oil Chem. In those tests, motor oil treated with zMax produced more than twice as much bearing corrosion as motor oil alone. The complaint also states that the defendants fabricated one "report" from the two test reports, eliminating the bearing corrosion results and all other negative test results, and then used that report and the "official laboratory results" - similarly edited to remove detrimental data results - as sales tools in the infomercial and on the zMax Web site."
As I have said before:
If the stuff is sold on Infomercials palmed off as car shows:
It's garbage.
If the stuff is hyped by some well known gearhead.
It's garbage.
If the stuff makes idiotic claims with vodoo physics to back them.
It's garbage.
Old Aug 6, 2009 | 04:47 PM
383vett's Avatar
383vett
Originally Posted by PLRX
STOP
No kidding, you ran your oil temperature up to 300 degrees? You better get yourself a new oil cooler before you need a new motor. Maybe the Zmax saved you.
Old Aug 9, 2009 | 09:05 PM
PLRX's Avatar
PLRX
2017 C4 of Year
Old Aug 10, 2009 | 12:01 PM
montecarlo4's Avatar
montecarlo4
i am not blaming zmax.
i did an oil change and used zmax about a week later my oil pump locked up.
the vette did have about 120k miles on it, so it could have just been the right time
thanks
matt
Old Aug 10, 2009 | 01:53 PM
GKK's Avatar
GKK
I used ZMax in my previous 91 Camaro and I didn't notice any difference in anything.
About 6 months later, I received a letter saying that I was a going to receive a settlement from ZMax from a lawsuit that was filed. A few months later, I received a check for the full purchase price.
Old Aug 10, 2009 | 02:14 PM
BrianCunningham's Avatar
BrianCunningham
From: Boston, Dallas, Detroit, SoCal, back to Boston MA
Old Aug 10, 2009 | 03:06 PM
PLRX's Avatar
PLRX
2017 C4 of Year
Originally Posted by BrianCunningham
I wanted something "different" with no C6 emblem
Old Aug 10, 2009 | 04:39 PM
bomar76's Avatar
bomar76
SUMMIT stickers (free) on your back window do more good for your engine and less harm than Zmax and all the rest of the snake oils.
It's all garbage.
Old Aug 12, 2009 | 11:55 AM
CAJUN C4's Avatar
CAJUN C4
It's all garbage.
Old Aug 12, 2009 | 02:09 PM
BIRDMANmx5's Avatar
BIRDMANmx5
Default the real deal
royal purple adds up to 15 hp.
Old Aug 12, 2009 | 02:41 PM
bomar76's Avatar
bomar76
...the key words being "UP TO"....
Old Aug 12, 2009 | 03:57 PM
RedCorvette1988's Avatar
RedCorvette1988
I knew my valve seals was bad but after using Z-Max it really started using oil. Took a couple of changes to get the junk out of the car. Never Again.
To Zmax
