Clutch, Synchros, or Normal?
Old Sep 16, 2009 | 04:18 PM
steven mack's Avatar
steven mack
What do you mean when you say you rotated the reverse lock out lever?
Old Sep 17, 2009 | 05:30 PM
1BAD88's Avatar
1BAD88
There is a steel rod that extends below the reverse lockout ring to prevent the shifter from going into reverse. That rod had one side that had a slot worn into it from 70,000 miles worth of shifts. I rotated that rod 180 degrees in the lockout ring so it could wear on the opposite side until I get the stainless steel version installed.
-J
Old Sep 17, 2009 | 06:05 PM
steven mack
O.K. I see what you mean.Where do you get the stainless steel ones?
Old Sep 17, 2009 | 06:40 PM
1BAD88's Avatar
1BAD88
I got a foot long piece of 1/8" diameter stainless steel rod and I intend to make it work one way or another.
