UJ Replacement without removing C Beam
I got all of the information here on the forum, after much research and I think it's extremely useful. It potentially saves 2-4 hours of labour and means the C beam stays aligned, with no chance of it not being done up tight enough, as well as avoiding the hassles of wrangling it out and back.
http://robhealey.com.au/Corvette/tec...j-replacement/
I really wish someone would fix the Tech tips, they are such a valuable part of the Corvette Forum.
Ok, so far I have paid people to do the plugs, but another mate gave me the tip to get a plug socket with flats on the top that a spanner fits, he reckons that makes the rear plugs much easier, putting a spanner on the plug socket instead of an extension sticking straight out.
Yep those tail lights are another PITA, but worse than that was fixing the rear bumper which after the repaint was put on with the corners way out of alignement. That took me all afternoon, using a jack, a flat timber stick and piece from a rubber thong - and of course I had to remove the two tail lights on that side.
