How do you clear historical codes on a 95?
One of the historical codes has been there ever since I bought the car and it was because of a faulty o2 sensor for the previous owner.
Thanks.
Oh yeah all last winter when it was stored I had it disconnected as well and the historical codes are still there so I don't think I can leave it disconnected much longer than several months.
Thanks again for the help.
Thanks.
To clear the codes on OBDII without a scanner.
1. With ignition "off" ground terminal #12 of the DLC (use bent paper clip to connect pin 4 to pin 12)
2. Turn ignition "on".
3. Press trip/odo button on the DIC until 1.7 appears in the trip monitor area of the instrument cluster.
4. Press eng/met button on the DIC & hold until "---" appears in the speedometer area of the cluster, this will clear CCM DTC'S.
To clear PCM/ECM codes do the following:
1. Press the trip reset button on the DIC until the desired system is displayed. In this case it will be 4.0.
2. Press trip/odo button on the DIC until the desired diagnostic mode (4.7) is displayed on the trip monitor area of the cluster.
3. Press & hold the eng/met button on the DIC until "---" is displayed in the speedometer area of the cluster, this will clear PCM codes.
To clear ABS/ASR codes do the following:
Same as above but you’re looking for “9.7” on the trip odo
