rough idle/ running rich on a cold start
Old Aug 8, 2009 | 01:35 PM
espop125's Avatar
espop125
Default rough idle/ running rich on a cold start
I have a 1986 Corvette and when I first start it idles rough and I think I can smell fuel like its running rich until the engine temp reaches about 110 and then smooths out. Is this the cold start injector or the temp. sensor? Any help please.
Old Aug 8, 2009 | 01:50 PM
Demonic85's Avatar
Demonic85
Are there any codes present? Specifically Code 14 or 15 (Coolant temp sensor low or high). If not then unbolt the cold start injector and turn the ignition to on to pressurize the fuel rail. If the CSI leaks then you found the problem.
Old Aug 8, 2009 | 09:12 PM
espop125's Avatar
espop125
no codes at all. I'm guessing to take the csi out I have to take the TPI off?
Old Aug 8, 2009 | 10:47 PM
Square's Avatar
Square
I don't think so. I have never just pulled the cold start injector on my 86', but from what I remember of my intake manifold replacement, I think the runners and plenum can stay on. It would be "crowded" in there with everything in place, but it may be possible.
Old Aug 9, 2009 | 10:17 AM
coupeguy2001's Avatar
coupeguy2001
2021 C4 of the Year - Modified Finalist
it comes out with difficulty, you might need to pull that rocker cover for some room.
be sure you get some orings before you pull the fuel line out of the fuel rail. Be sure that you depressurize the rail before pulling stuff off of it, you might get a face full of gas.
Old Aug 10, 2009 | 03:42 AM
espop125's Avatar
espop125
Coupeguy2001 so you agree it can come out without having to take the plenum and runners out? Also you mean the valve cover needs to come off right? And do you know where I can get a replacement CSI?
To rough idle/ running rich on a cold start
