Noise/rattle under front bumber
runs and drive great but if you run over the least bit of a rough spot - the front end rattles bad. does not shimmy and it is not out of line. someone told me it needed new rack and pinion -
what could this be
also has high idle - round 1800 rpms - any suggestions to fix this
The rattles can't be the rack. Usually rattles are associated with body parts. Try crawling under the front and tapping things with your fist lightly. Usually you can duplicate the shock to the car that is transmitted from the tires.
Use the tires as a beginning..........go to the shocks, then sway bar, then control arms, etc.
AutoZone sells them as part of a kit. $12 or so.
