I have this brake noise,it usually start to happen when the car reaches normal temps or mostly when i have been using it for the day,i think when brakes get hot.- Its like the caliper crunches when i apply the brakes,here i recorded and uploaded this noise,i have lost the brakes (they go to the floor) and i think its brake related (maybe abs pump) because the abs start to pulsate i think when the brake is to the floor...i already have a new master cyl ,but i haven't installed it so i have no idea if its this the cause for the loss,after i pump them 2 or 3 times,they come back but they are long traveling brakes when this happen and ....this happens when its hot as well !
You can clearly hear this sound on this video !
And im sure some of you have this problem as well !
That's exactly the noise im hearing !
i thought that thing under that carpeted door was the fuel pump !
Im sure some of you can confirm,im not sure if the fuel pump is on the tank
anyway my noise comes from the caliper crunch crunch !
