Yet Another Anti-freeze question
Old Aug 9, 2009 | 11:58 AM
pmihaltian's Avatar
pmihaltian
Slingshot
Default Yet Another Anti-freeze question
Which antifreeze is green and which one is orange? Are Prestone & Peak green?
Old Aug 9, 2009 | 12:05 PM
c4cruiser's Avatar
c4cruiser
Green coolant is ethylene glycol and was the standard coolant for many years in almost every vehicle. Coolant with a red to orange tint is a Dex-Cool type used by GM since 94 or 95. The two are not compatible. There are some coolants that are yellow in color and are supposed to work with either type.
You can find both the green and red coolants from a wide variety of brands. Prestone makes both types as does Peak. Check the label to see what type of coolant it is.
Old Aug 9, 2009 | 12:21 PM
pmihaltian's Avatar
pmihaltian
Slingshot
Thanks much
Old Aug 10, 2009 | 12:59 AM
Corvette40's Avatar
Corvette40
I had my water pump rebuilt at a local corvette shop and they refilled my $500.00 Dewitt radiator with Dexcool. I have an 88 and it is an open system. A brown tar like substance started clogging my radiator and I was highly upset. I looked everywhere for the "green stuff" and finally found it at PepBoys. I can't remember the brand but it was a black jug with a label that said it was the old green formula right on the front. Two flushes later and no more brown tar.
Old Aug 10, 2009 | 04:23 PM
MK 82's Avatar
MK 82
You can't go strictly by the color anymore.
Old Aug 11, 2009 | 01:34 AM
eguyett1985's Avatar
eguyett1985
I'm doing a water pump on a 96 right now and found some of that tar-like buildup in the system, doing a very, very through flush with distilled and I'm going with the Zerex GO-5 and distilled based on the information shared here.
Old Aug 11, 2009 | 02:43 AM
larryfs's Avatar
larryfs
walk into pep-boys and there are so many types of antifreeze your head will explode. at least 10.
Peak still sells the old green stuff at ACE hardware.
Old Aug 11, 2009 | 12:18 PM
jhammons01's Avatar
jhammons01
Ethylene Glycol is as clear as water. The color dye added to it is the manufacturers choice.
I used to work for coolant recyclers We used Reverse Osmosis to filter the used coolant. It came out of the membrane filter clear...we'd drip Green Dye into it.
I'd still say stay away from DexCool.....not going to get into why......
And with the introduction of Aluminum components to engines or cooling systems, I'd suggest using Propylene Glycol over Ethylene Glycol...
Old Aug 11, 2009 | 12:45 PM
bowtie350_428's Avatar
bowtie350_428
How about that yellow stuff that prestone makes that is supposedly compatible with all types of antifreeze? Will that cause problems if you previously had green or orange coolant in your system?
To Yet Another Anti-freeze question
