Another '88 Fuel System Question
Old Aug 9, 2009 | 12:04 PM
es's Avatar
es
Default Another '88 Fuel System Question
In my other post about the '88 not starting I noted that I unplugged the connector that is next to the filler neck. I assume this is fuel pump power. With this unplugged there is still a reading on the fuel gauge on the dash. Where does the wiring for the gauge sender come from? I don't see any other wires going into the tank.
Old Aug 9, 2009 | 12:27 PM
jfb's Avatar
jfb
The fuel pump motor wire is tan/white, the other wires on this connector go to the in tank gauge sender.
Old Aug 9, 2009 | 12:40 PM
es's Avatar
es
Where does the fuel pump get its ground? Is it not one of the 3 wires in the connector? Does ground come through having the mounting plate connected to the tank?
Old Aug 10, 2009 | 08:26 AM
jfb's Avatar
jfb
The motor grounds to the fuel tank.
To Another '88 Fuel System Question
