Will I be able to do this for around $500?
Old Feb 16, 2002 | 07:12 PM
Jedi404's Avatar
Jedi404
Default Will I be able to do this for around $500?
New valve gaskets(if I buy the gaskets myself) and new brakes? I could probably do the brakes myself, but might as well do it while im there. Thanks! :cheers:
Old Feb 16, 2002 | 07:21 PM
AS84's Avatar
AS84
Default Re: Will I be able to do this for around $500? (Jedi404)
Should be able to. I guess it depends on the thickness of your rotors. If they are below minimum specs then they should be replaced as well.
Old Feb 17, 2002 | 03:36 AM
65Z01's Avatar
65Z01
Cruise-In II Veteran
It's tedious getting the valve covers off a L98. Get some FelPro PermaSeals if you do it.
When I do brakes on a car with some mileage I like to do rotors, calipers and pads at once. Also flush the fluid as it picks up moisture over time.
Old Feb 17, 2002 | 08:15 AM
Vvcdde's Avatar
Vvcdde
In brake parts for new rotors and pads it sould run you around $500. Prolly less, but that is a conversivtive estimate. ($90x2 for front rotors, $80x2 for rear rotors. $100 for front pads and $90 for rear pads). Thats right about what it cost me when I did my brakes.
Valve gaskets. I wanna say about $150 for the parts you will need.
Old Feb 17, 2002 | 02:40 PM
M2001's Avatar
M2001
Default Re: Will I be able to do this for around $500? (Vvcdde)
"Valve gaskets. I wanna say about $150 for the parts you will need."
You mean $15, don't you? I think I spent about $15 or so for the Felpro synthetic valve cover gaskets.
Old Feb 17, 2002 | 03:24 PM
AS84's Avatar
AS84
Default Re: Will I be able to do this for around $500? (M2001)
My valve cover gaskets were 30 bucks at autozone.
Old Feb 17, 2002 | 03:25 PM
Vvcdde's Avatar
Vvcdde
Fat fingers on my part :)
Old Feb 17, 2002 | 07:43 PM
M2001's Avatar
M2001
I was gonna say, if you paid $150 for valve cover gaskets, stay as far away as you can from that parts dealer....LOL
To Will I be able to do this for around $500?
