Tech help for gears please.....
Old Aug 10, 2009 | 07:21 PM
ks5shooter's Avatar
ks5shooter
St. Jude Donor '10-'11-'12-'13
Default Tech help for gears please.....
I have a 93 with 259 gears .I want to go to 373's.How do I know which gear variation to order,which housing do I have?Is the info on my spec sheet?If not then where?
Old Aug 10, 2009 | 08:14 PM
rodj's Avatar
rodj
All auto cars have Dana 36.
You need a Dana 36 gear set with "thick" gears to reuse your existing 2 series carrier.
http://www.corvetterecycling.com/category_s/441.htm
Old Aug 11, 2009 | 12:36 AM
reoch999's Avatar
reoch999
You've got a 2 series D36. If it came stock with a 3.07 (I believe the RPO code was G44 & G92), you'd have the 3 series.
You can get 3.75:1 gears for either one, but they are not interchangeable. A 2 series needs a thicker ring gear than a 3 series.
The D44 only came with manual transmissions.
Old Aug 11, 2009 | 07:17 AM
ks5shooter's Avatar
ks5shooter
My spec sheet says 259's where do I find the RPO code ?thanks
Old Aug 11, 2009 | 12:03 PM
reoch999's Avatar
reoch999
My RPO codes are on a sticker in the center console, under the arm rest.
Old Aug 13, 2009 | 07:16 AM
ks5shooter's Avatar
ks5shooter
Thanks all much appreciated got to go get my gears
To Tech help for gears please.....
