Rebuild or new engine?
Old Aug 10, 2009 | 07:26 PM
bolowbc's Avatar
bolowbc
Default Rebuild or new engine?
Hey guys,
So my WP recently failed, resulting in super high temps and head gasket failure.
So the options now are to get a rebuild for around $2K... or possibly a new LT1 for $2-$3k more. Because this wouldn't be swapping in a performance engine, my question is whether a new engine would save $2-4K in maintenance down the road? Is it worth the extra cash, or a rebuild is the way to go?
I'm on a budget, and that money may be better spent on suspension and other parts of this 15 year old car.
Let me know what you think!
-Will
Old Aug 10, 2009 | 08:02 PM
Mojave's Avatar
Mojave
I'd definitely rebuild it. Any competent machine shop should be able to handle it, and if the heads or block are too warped to save, they should be able to let you know. I would not waste the money on a new engine.
As far as maintenance, I would replace all the consumable items while the engine is out: belt, hoses, thermostat, spark plugs, plug wires, water pump, etc. When it goes back together it will be as good as new.
Old Aug 10, 2009 | 08:29 PM
neverendingprojects's Avatar
neverendingprojects
I would just go with a complete rebuild of your existing engine with possibly the addition of some High perf. parts.
Fixing a blown gasket just seems like a whole lot of labor, and there is still a possibility that the other Head gasket can fail as well!
Old Aug 10, 2009 | 08:31 PM
PLRX's Avatar
PLRX
Co-winner 2020 C4 of the Year - Modified
2017 C4 of Year
2016 C7 of Year Finalist
St. Jude Donor '09 thru '20
Rebuild
Hey, this is the time to make a hardcore decision for future NOS, supercharger etc.
Never Say Never
Old Aug 10, 2009 | 08:53 PM
pologreen1's Avatar
pologreen1
there is a lingenfelter 383 in the F/S section for like 5500
Old Aug 10, 2009 | 09:50 PM
Randy93's Avatar
Randy93
St. Jude Donor '06
How many miles, I had the same thing and I just replaced the gaskets and was fine.
Did you seize the engine?
Look at Summitracing they have GM blocks and and short blocks for good prices.
Old Aug 10, 2009 | 11:59 PM
bolowbc's Avatar
bolowbc
Yeah good tips. I plan to do the plugs, wires, WP, and opti. Thermostat is new, but I will make sure they do the belt + hoses.
Rebuild +2
Originally Posted by PLRX
Rebuild
Never Say Never
Haha! Rebuild +3
Thanks, I'll check it out.
At the risk of sounding stupid, how can I tell if I seized my engine? It still runs, so I don't think so...? I was expecting a rebuild down the line, but not so soon. Oh well, get it done and out of the way. The car has 85,000 miles on it.
Old Aug 11, 2009 | 12:10 AM
Mojave's Avatar
Mojave
If it is sized, it won't turn over. If it still runs, it is definitely not seized. A seized engine wouldn't turn over on the starter or by hand (with a big wrench on the crank bolt).
Old Aug 11, 2009 | 11:40 AM
DonF's Avatar
DonF
Where are you located?
Old Aug 11, 2009 | 01:34 PM
Chapindad's Avatar
Chapindad
This was a great question. I have a motor with 196k on it. It is running great but I am waiting for when it loses the head gasket and I have been wondering the same thing.
Old Aug 11, 2009 | 02:33 PM
kangi's Avatar
kangi
I would rebuild, heck you can save a boatload of $$ by doing a lot of the labor yourself, plus as mentioned above you can prep your motor for all sorts of high performance goodies
Old Aug 11, 2009 | 02:51 PM
BADDUCK's Avatar
BADDUCK
From: One day you're a Comet...the next day you're dust... Arkansas
I would rebuild. You may just be able to simply mill the heads, which will raise compression a bit and have a 3 angle valve job done. While it's apart new full RR's are a good upgrade. Also possibly injectors if they are old. If your bottom end is good you should be good to go.
Old Aug 11, 2009 | 06:10 PM
bolowbc's Avatar
bolowbc
Southern CA.
Thanks, I'm glad it's helpful to more than one person That's great you've got 196k on it and going strong! I thought this one was going to be too.
Haha yeah I know. It happens to be my daily driver, and I can't afford the time right now.
Hmmm... I was thinking about doing RR's. Budget-wise, I may put it off until later though. I will be sure to ask the shop on the condition of injectors.
Old Aug 11, 2009 | 06:21 PM
TheCorvetteKid's Avatar
TheCorvetteKid
Forgive me if this sounds a bit naive, but your original post said your engine suffered head gasket failure which caused a sever overheating condition. Unless you've cracked the block, why are you considering a rebuild?
My '89 suffered a severe overheat condition when one of the head gaskets failed, resulting in a cracked cylinder head. I purchased a used set of heads from another '89 Corvette, had them reconditioned, installed them and was back on the road in a matter of a few of weeks (I worked slow). I wouldn't even have considered a full engine rebuild for something like a head gasket failure. Of course, if the block had cracked that would have been a different story (engine replacement is pretty much the only option when that happens).
So is there any particular reason why a blown head gasket has you thinking of a full engine rebuild?
To Rebuild or new engine?
