C4 Hood Latch Problem
Old Feb 16, 2002 | 08:40 PM
Ron04,02,96,64's Avatar
Ron04,02,96,64
Default C4 Hood Latch Problem
One latch will not release unless I press down with a lot of force right over the latch while someone else pulls the inside lever. With the hood up, the cable and release lever work just fine. I believe, although I'm no expert, that the spring is either too compressed or too little and I've adjusted it a little in both directions with no improvement. Ideas anyone??
Old Feb 17, 2002 | 12:31 AM
PurpleC4's Avatar
PurpleC4
Cruise-In I Veteran
Cruise-In II Veteran
Currently Corvette-less
Default Re: C4 Hood Latch Problem (Ron99/64/57)
You can solve the problem by buying the hood latch upgrade kit from Jeff Kopp at (800) 728-8267. The kit comes complete with latch plates, pins, springs, cable, and release handle. Surprisingly it is not too expensive.
You will be glad that you have done this. The new kit tends to tighten the fron end (hood area) and your hood will actually pop up 2 or 3 inches when released.
:seeya Purp
Old Feb 17, 2002 | 12:41 AM
Ramrod92's Avatar
Ramrod92
What Purp said. The old springs look like they came from a mattress, while the heavy duty ones look more like a valve spring. Only problem I had was you need a very large wrench( I think 1 3/4) to install them. :cheers:
Old Feb 18, 2002 | 08:29 PM
PurpleC4's Avatar
PurpleC4
Cruise-In I Veteran
Default Re: C4 Hood Latch Problem (Ramrod92)
Ransome,
I used a 15: crescent wrench to remove the jam nut. It only took a little pull and it broke loose. After that, it stayed on the pin as I twisted it out of the hood.
Purp
Old Sep 17, 2010 | 11:59 AM
oldalaskaman's Avatar
oldalaskaman
Purp
I called Jeff yesterday for this kit, he no longer has it but Corvette Recycling does have it . Its a new in the box kit and has the upgraded springs. It was only $49 and for my money , one good deal
Old Sep 17, 2010 | 12:49 PM
CorvetteRecycling's Avatar
0CorvetteRecycling
Former Vendor
Here is a link to the kit: http://www.corvetterecycling.com/product_p/10273994.htm
Old Sep 17, 2010 | 01:43 PM
ElvisGraceBo's Avatar
ElvisGraceBo
I did my emergence pulls myself. Found them on a search for emergency hood latch release, cost me like $8.
The kit looks awesome, complete.
Old Sep 22, 2010 | 08:30 PM
oldalaskaman
I got the hood latch upgrade kit from Corvette recycling today and installed it . It works perfect, and after fighting with the original ones for over a month, this upgraded kit is a pleasure. It worked the first time and makes the hood more solid. I am happy
Old Jan 14, 2011 | 05:12 PM
Baldfart's Avatar
Baldfart
Originally Posted by CorvetteRecycling
I bought this kit from them. Smokin' deal!
Old Jan 14, 2011 | 05:57 PM
oldalaskaman
mine is the best thing I've bought so far.
Old Jan 14, 2011 | 06:25 PM
RICEKILA's Avatar
RICEKILA
From: Beautiful Down Town "SWINDLEHURST" Long Island NY
The beginning of this past summer - mine started to act up
In my case - spraying every thing with wht. Lithium grease worked
But I'm gonna book mark that site
Old Jan 15, 2011 | 11:22 PM
redrose's Avatar
redrose
Default never do it without lube
the 'male' latch (the part that screws into the hood) needs grease BEHIND the point...rust at that spot creates extreme friction...grease applied to the male will rub off on the 'female' lower latch (bolted to the cowl) and after a few days all will be well.
Old Jan 16, 2011 | 12:35 AM
l98tpi's Avatar
l98tpi
Max G’s
I actually broke my hood release latch, inside car under dash. I sprayed down with white lithium grease and worked the cable and latch and they worked fine with little to no resistance. Ended up adjusting the bump stop and works fine now. For any future visitors to this thread, maybe this could be a course of action before replacing latches.
Old Jan 16, 2011 | 03:01 AM
oldalaskaman
the complete kit from corvette recycling has upgraded springs included that eliminate all this 'grease it ,spray it, adjust it, play with the latches every time you'ld like them to just work, agravating mess' , for the cost of what other venders are selling individual parts for without the upgraded springs. you folks can do or buy anything you like.
To C4 Hood Latch Problem
