I have a '96 LT1 that has just turned over 100,000 miles and I want to put in new plugs. The owner's manual doesn't say what plugs to use when replacing them. I assume they recommend AC-Delco, but is there a better plug to use. Most of my driving is around town. No high speed runs to the border or anything like that. Everything is running smoothly, but I think 100K is plenty of a set of plugs.
wrong with the AC Delco,I have heard NGK are good but pricey...
You can use the regular NGK Tr-55s and they are pretty cheap. The iridiums and Platinums are the expensive ones but then again any of those extended plugs are expensive. The NGKs are a great plug. No problems whatsoever.
Nothing as long as they have fixed the problem with the pucks falling off the electrodes of their platinum plugs. (And I really believe they have.)
FWIW I use the NGK iridiums. I also feel that the sparkplug offers a unique diagnostic window into engine health. I will change them at or near 30k just to see what they look like. I could put the plugs back in, in some cases, I suppose. But with the PITA that they are to change, I put in new. I'm not arguing that I've got all the answers for plug questions but this is what works for me. YMMV
Yeah, I've read of the pucks falling out of the AC Delco plantinums. Beside, I think they are just getting an aftermarket plug maker to make thiers, right?
The regular copper plugs are now made of metal that will rust, ala Autolite. The bases of the plugs were rusted out in less than a month. I took them out and returned them and got some copper NGK. The original AC Delco plugs that came on my 89 are made of a metal that doesn't rust. And the porcelein on the new AC Delco has some ridges on it the original didn't have. So, they aren't being made the same anymore.
I just blew like $5 a plug on some Bosch platinum +4's and didn't really notice much difference, seemed to smooth the idle out a bit, could be psychological though Also added MSD wires. It was one of those "just felt like it" kind of projects.
I just replaced plugs on my 89 Coupe, stock 350 no mod's. I went with recommended AC Delco ($17 including tax for eight) vs. $3-7 for other. Car runs great.
I'm guessing you went with the FR5LS? Check and see if the nut on them rust out.
My 96' with 109k will get E3s when I change them. I saw the Dyno test on a weekend past. It was either Horsepower or Hotrod TV and it showed a 5hp gain before and after, although on a later show they said 7hp.
7hp between brand new plugs Ill never believe it, especially rwhp.
If the ones you have are old and worn out then might pick up a few chp
All a plug has to do is throw the spark across the gap to ignite, once its lit the mixture thats it.
All that fancy crap on a stock car wont make a bit of difference.
