Drag Radials
Old Feb 16, 2002 | 08:58 PM
StealDads67's Avatar
StealDads67
Default Drag Radials
How much would Drag Radials run for a 89 Vette?? Who makes the best ones?? Any input on them and what is normal about of time it takes off the 60' and ET??? Thanks Guys :cool:
Old Feb 16, 2002 | 10:23 PM
85vet's Avatar
85vet
Cruise-In V Veteran
Default Re: Drag Radials (StealDads67)
Check out the wheels & Tires section. There are constant debates on this subject.
Old Feb 16, 2002 | 10:51 PM
RatRacer's Avatar
RatRacer
You have two choices, Nitto or BFG. The Nittos are longer lasting and the tread handles wet roads better. They require a lengthy burn out to be tacky.
The BFG's are quite a bit stickier but last about half as long (5k miles). They require a shorter burn out and give better 60's. I run 1.80 sec 60's with them on my stock geared ZR-1
The Nittos are slightly more expensive but that is offset by the fact that they last twice as long. Personally, I like the stickier BFG's.
To Drag Radials
