Engine codes Service Engine Soon 43 & 52 ??
Old Aug 11, 2009 | 06:28 AM
Macfly's Avatar
Macfly
Default Engine codes Service Engine Soon 43 & 52 ??
Hi Guys
I have the light SES switched on permanently by driving for the first time.
I followed the method to find the codes and Here they are:
43 : Electronic Spark Control
52 : Fuel Calpak Missing
I have verified connectors and open PCM for look the calpak and put sillicon but I always have the problem.
Besides, my C4 lost of its power, that feels easily.
Thank you for your help
Patrick
Old Aug 13, 2009 | 06:58 PM
billvh's Avatar
billvh
I've had code 52 also, I think it's an oil temp problem on Corvettes.
Old Aug 13, 2009 | 08:09 PM
Paul Ruggeri's Avatar
0Paul Ruggeri
Former Vendor
Code 43 is most commonly a bad knock sensor. Code 52 is most commonly a bad oil temp sensor. You need to look at scan data to see the readings from these sensors.
Bonne chance, Paul
Old Aug 14, 2009 | 03:40 AM
Macfly's Avatar
Macfly
Thx a lot my friends I will watching this, because i'm thinking my ECM is out of order
Old Aug 18, 2009 | 08:47 PM
JD94C4's Avatar
JD94C4
Originally Posted by Macfly
Hi Guys
Patrick
Patrick, I also have service engine soon. where can I go to determine WHAT code or codes are the cause? thanks
JD
Old Aug 19, 2009 | 03:53 AM
Macfly's Avatar
Macfly
JD
Hi JD !
I find this process, i think it can help you
http://www.corvettebuyers.com/c4vettes/codes.htm
Patrick
Old Aug 19, 2009 | 07:50 AM
JD94C4's Avatar
JD94C4
thanks Patrick. I will look into that.. my car seems to be running great so it cant be that serious, just the annoying light
JD
To Engine codes Service Engine Soon 43 & 52 ??
