Code 43 and 52 Help, Please ! 90 model L98
Old Aug 11, 2009 | 10:06 AM
Macfly's Avatar
Macfly
Default Code 43 and 52 Help, Please ! 90 model L98
Hi Guys
I have the light SES switched on permanently by driving for the first time.
I followed the method to find the codes and Here they are:
43 : Electronic Spark Control
52 : Fuel Calpak Missing
I have verified connectors and open ECM for look the calpak is fixed OK and put sillicon but I always have the problem.
Besides, my C4 lost of its power, that feels easily. She's in limp mode in fact...
Thank you for your help
Patrick
Old Aug 12, 2009 | 06:24 PM
vette079's Avatar
vette079
Read this one and see if you can use the info, it´s almost the same problem.
http://forums.corvetteforum.com/c4-s...e-42-help.html
Old Aug 13, 2009 | 05:49 AM
Macfly's Avatar
Macfly
Thx. I read this one before i post but i verified all they said
I think my ECM is out of order, right ?
I must made an order for a new or remanufactured
Old Aug 20, 2009 | 09:53 AM
woodstock's Avatar
woodstock
Did you replace the knock sensor or tested it at least?
A bad sensor could have taken out the ECM or less likely the memcals knock sensor circuit board.
If you don't have anybody in your neighborhood with a 90 or 91, you could mail me your memcal and I could check if the problem travels and shows up in my Vette as well.
Old Aug 21, 2009 | 04:00 AM
Macfly's Avatar
Macfly
THX my friends, in fact, it's my oil sensor on the block was disconnected
After re-connect the codes disapears but my oil temp gauge is dead
To Code 43 and 52 Help, Please ! 90 model L98
