I think my ProCharger spun the bearing again. Shaft it moving and blades are hitting the unit. In 2000 when I first bought my blower with in months of the install I had oil in the intake. Teflon seal was bad or had gone out. Fixed under warranty. Then in 2003 just day with in warranty it spun a bearing and was fixed under warranty. I might have put 5000 mile on it in total. I read some time back that some one was fixing these with ceramic bearings. Where should I send this to get fixed or can I get the parts and rebuild it at home and save on shipping time and labor? Thanks Douglas
would speak directly with Procharger about this, that is ridiculous that all that has happened with yours....Do you have enough oil pressure?????
I have had no problems with mine, allthough it is loud as hell, which im not sure if that is normal for p600b's, other chargers ive heard arent as loud
Completely normal with a P600B, and has to do with the straight cut gears in the trans.
