Hesitation Problems, Rough Idle
Old Aug 11, 2009 | 08:57 PM
VetteManHand's Avatar
VetteManHand
Default Hesitation Problems, Rough Idle
I have a 1994 coupe with about 120,000 miles on it. For about the past three weeks its been giving me all sorts of trouble. When i start up the idle is reallly rough like its camming hard but in park if i bring the rpms up to about 1500 and it smooths out. When I'm driving it i have to shift it manualy or else there is no chance of me moving forward with any motivation. When I get on the throttle more than 50 percent I am often met with a pinging sound and severe hesitation that smoothes out as the rpms increase. It almost acts like its starved for fuel so I removed the fuel pump to test it. I turned the key to run and the fuel pump shot a healthy and powerfull stream of fuel out. Spark plugs and wires are both about a year old
Old Aug 11, 2009 | 11:18 PM
jimg's'93's Avatar
jimg's'93
Could be a number of issues. Check for any codes and post them to begin with. That'll help narrow it down.
2 things you might also check might be:
Your plug/coil wires. In a dark garage, run the motor and look for arching.
Clogged cats.
