Help getting knock sensors out...LT1
Old Aug 11, 2009 | 09:44 PM
9T3VETTE's Avatar
9T3VETTE
Default Help getting knock sensors out...LT1
Well i am tackling the water pump and i am stuck on step number 1, getting the coolant out. The nut is already striped on both of them!!
So i searched and found that putting vice grips on the rounded portion of the sensor has yielded postive results for some people. Not for me, they haven't even budged. I have used pb blaster and everything i can think of!
So here is my question, will a torch and heating them up get these bastards out?
I wish i would have stumbled upon the method of blowing the coolant out with a shop vac out before i messed the sensors up, but now my guess is they have to be replaced.
Old Aug 11, 2009 | 10:31 PM
Black94LT1's Avatar
Black94LT1
Cruise-In 10-11-12 Veteran
St. Jude Donor '09-'10-'11-'12-'14
I have never had a problem getting them out, but I would agree that you have probably committed to it now. If you go for the torch be careful no the butn up some wiring, etc as that area is pretty tight.
Old Aug 11, 2009 | 10:53 PM
PLRX's Avatar
PLRX
Co-winner 2020 C4 of the Year - Modified
2017 C4 of Year
2016 C7 of Year Finalist
St. Jude Donor '09 thru '20
Use a pipe wrench and buy new KS
I assume you removed the shields...
Old Aug 12, 2009 | 08:09 AM
9T3VETTE's Avatar
9T3VETTE
yes i removed the shields....The bozo who owned/worked on the car before me must have torqed them down wayyyyyy to tight or put some sealant on them. I mean come on they are only supposed to be torqued down to 14ft/lbs.
I'll try the pipe wrench and order some new sensors today.
Old Aug 12, 2009 | 12:40 PM
onedef92's Avatar
onedef92
Cruise-In IV Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
Cruise-In VIII Veteran
Mine were in tight, too. I used a pair of locking vice grips to coax mine out. The round part of the sensor is actually pretty sturdy and robust. It's the plastic connector "nipple" that's fragile and easy to shear off.
I'd replace them with genuine AC/Delphi sensors, too. Some cheapie aftermarket brands like Wells (VatoZone) aren't calibrated to factory specs and can actually create a false Code 43 (knock sensor circuit).
Old Aug 12, 2009 | 12:59 PM
IRAraid's Avatar
IRAraid
Default Knock Sensors
The hex on my '95 knock sensors were gone too.
Good excuse to buy a huge set of water pump pliers (channel locks). I tried a pipe wrench but it was too big to fit (about 4' long). As mentioned, the body of the knock sensor was plenty stiff enough to handle the load.
Have new ones in hand and be ready for the flood. If there's no flood, use a screw driver to break the crust.
Old Aug 12, 2009 | 01:05 PM
9T3VETTE's Avatar
9T3VETTE
Cool, thanks guys i'll give it a shot when i get home.
Old Aug 13, 2009 | 07:50 AM
9T3VETTE's Avatar
9T3VETTE
Lots of heat and a pipe wrench finally broke them loose
Thanks everyone
Old Aug 13, 2009 | 08:22 AM
onedef92's Avatar
onedef92
Thanks everyone
What brand sensor did you replace them with? Remember, the orange coating that comes on the new sensors is all you need. DO NOT use thread compound or plumber's tape on the new units.
Old Aug 13, 2009 | 10:06 AM
Black94LT1's Avatar
Black94LT1
Extra sealant can cause bad knock readings and error codes.
Old Aug 13, 2009 | 09:56 PM
9T3VETTE's Avatar
9T3VETTE
^^Cool thanks guys. Not sure what brand I am gonna replace it with. Still got to make it up to the store to see what they got.
Old Aug 14, 2009 | 11:39 AM
onedef92's Avatar
onedef92
As previously stated, the smart money's on genuine AC/Delphi.
Old Aug 14, 2009 | 11:48 AM
PLRX's Avatar
PLRX
2017 C4 of Year
The KS are to be hand tight or up to 22 ft-lbs. Use a light coat of sealant
Old Aug 14, 2009 | 12:38 PM
onedef92's Avatar
onedef92
I believe the FSM states do NOT use extra sealant, just the orange coating from the factory. Extra sealant can cause bad knock readings and error codes because the acoustic coupler's (actually a tiny microphone) sensitivity can be negatively affected.
Old Aug 14, 2009 | 12:54 PM
PLRX's Avatar
PLRX
2017 C4 of Year
well, if it comes with it who would put more?
Old Aug 14, 2009 | 01:49 PM
onedef92's Avatar
onedef92
Your previous response could be construed to mean YOU might. I'm not saying you did, I just don't want the OP to erroneously add extra sealant to the device when none is needed.
To Help getting knock sensors out...LT1
