So I'm reading this book by Herb Adams and in it he mentions that due to the fact that poly bushings bond to the metal that they are inserted into, that they actually inhibit handling capability...I realize that this was written in '91 but have there been any advances in poly technology to make them work better? I mean, Herb Adams has practically deified in Chassis building lore....
Anyone have any thoughts on this....I have my suspension ropped apart and before I make the biggest mistake in a long time...I'd like to have an idea about how to proceed...
But I would speculate that any bonding would be the result of inadequate lubrication during assembly.
In my own experience I use poly bushings and have never had a problem.
what I will say is that when you assemble your bushings, LUBE EVERYTHING, bushings, inserts, brackets, everything. That puny little squeeze tube of grease that comes with the bushings is nowhere near enough. Use a good quality chassis or wheel bearing grease and use lots of it. Good luck
He speaks about the lube and that in a few weeks, dirt, grime, etc. renders it useless....maybe we have better lube now?
Here is the problem I have with poly in the rear dogbones. The halfshaft camber rods swing in an arc when there is suspension travel rather than perfectly straight The dogbones have to swing an arc as well so the bushing has to be compliant in more than one dimension. Anything you do to firm up the bushing will restrict the motion for the dogbone to travel in two planes at the same time. In my mind you either need a compliant bushing that will allow the travel in two planes at once but lose precision or a heim joint that will allow the travel and maintain precision. My .02 it's free YMMV..
Also they now have poygraphite impregnated bushings which supposeldy help the squeak syndrome (Ill find out soon). From others Ive driven though not sure I would do it again. Rubber seems to be the best overall for a street car. Last one even though all new and lubed up squawked like crazy going over speed bumps in a parkling lot it was downright embarrassing.
This winter I am going with heim joints in the rear with the seals-it boots to keep the dirt out. It may or may not be too much but worth a try vs. all the squeaks and binding. I have entertained making some mono-***** for the front and see no reason for the to cost as much as I have seen the sell for. If it works will make a kit up the average bear can install in their garage.
I can confirm the grease doesn't stay long. Some people drill and put a zerk in to keep adding grease. Rubber you don't grease so that it can bond and twist.
Just a thought, looking at my spindle rods where I just put in some polys, the only place the rods have to move is where the insert sleeve meets the bolts. The bushings can adhere to the strut rod without a problem.
I've got the most experience with the sway bar mounting bushings. I can tell after awhile as the ride harshens that the grease has gone away. The extra friction makes more dampening as the bar doesn't rotate freely anymore. I'm thinking of just greasing the bars every year or putting in a zerk.
Say man......tell me about that collie dog in your avatar. He/she looks alot like two of mine that I have had to say goodbye to(had to put them to sleep). Are you a collie guy too????? Out of 5, I only have one old boy left. Randy
That Collie in the picture was the 4-legged love of my life...he was the very best friend I have ever had, no matter how many legs...His name was "Braveheart"('Connor')McCloud...I had to put him down this year, 25 days shy of his 10th birthday, due to cancer...he died in my arms...I miss him every minute of the day...He never displayed a single symptom...I lost him in 4 days...every person who knew him wept when I told them...he had many many friends...One of them was a dog-hater until he met Connor...he used to come to my house and walk Connor when I was at work....I never asked him to...a few months later, he bought a dog of his own, and they are inseparable...Connor had that effect on everyone he met...sorry for being log-winded but I miss him terribly...
Yes I am a Collie Guy...he was my Second.
just saying the rapid change from bushing to the dog
didnt mean no harm by it
just struck me as funny
but sry for your loss. Im dreading the next 2 years as my great dane just turned 7 and thats tipping the scale for them
No offense taken...I was trying to lighten the mood...and thank you...
Yes, My daughter has a Female Great that she is very attached to...we are dog people by nature...Jade is only 3 right now but it will be hard on my daughter when the time comes...
Jade however, will not fit in the cargo area of my coupe, so...now we're off topic
