6-speed shift knob..Will it work?
Old Aug 14, 2009 | 11:44 PM
darkstallion_69's Avatar
darkstallion_69
Default 6-speed shift ****..Will it work?
Im planning on buying this shift **** because mine is falling apart and I can't stand the way it looks. I wanted to run it by you guys first. I have noticed not many people have different shift ***** and I heard many companies dont make it for the c4. This **** says it will fit 90-96.. any opinions???
http://www.kirbanperformance.com/pro...N+%231395.html
Old Aug 15, 2009 | 07:48 AM
RollaMo-LT4's Avatar
RollaMo-LT4
St. Jude 15 Year Donor
2021 C4 of the Year - Unmodified Finalist
St. Jude Donor '10 thru '25
I believe that will fit just fine. At least it's got the correct shift pattern on it.
You can still find the Hurst shift ***** on E-Bay also.
Old Aug 15, 2009 | 01:04 PM
SGAL1's Avatar
SGAL1
Ecklers has this one which is a nice stock replacement
http://www.ecklers.com/product.asp?p...6&dept_id=1635
However if you are patient...you can do what I did and find someone who is parting out and has an original to sell you.
It took me quite some time to find the right one...but I was glad I waited because the one I found here on the forum is as good as new.
Old Aug 16, 2009 | 12:23 AM
mtwoolford's Avatar
mtwoolford
summit pn # HUU1630055, hurst shifter ball for ZF 6 speed with the correct shift pattern, white, black is also available, $43.95; I really like mine, and no, I never liked the stock shifter ****, it never felt right and then the stitching started to go.
Old Aug 16, 2009 | 12:28 PM
darkstallion_69
the one they show has the wrong shift pattern....
Old Aug 16, 2009 | 04:58 PM
mtwoolford's Avatar
mtwoolford
trust me, what they show is not always what you get ("the part shown is for illustration purposes only, the actual part may vary"). For some reason the Hurst shifter ***** for c4's with ZF 6 speed's fly beneath the radar. The part number I posted is the right number for the shifter **** you want (assuming you want a white ****; black has a different number). It has the correct c4 shift pattern (not the c5/c6 pattern) Give Summit a call & confirm.
To 6-speed shift knob..Will it work?
