injector removal
Old Aug 15, 2009 | 04:15 PM
hgh pwr's Avatar
hgh pwr
Default injector removal
How do you remove the injector from the fuel rail on a lt1(94) without damaging them. thanks
Old Aug 15, 2009 | 04:56 PM
94z07fx3's Avatar
94z07fx3
Disco the harness from each injector by pushing on the little wire clip and wiggling as you pull up. Remove the four bolts holding rail to intake. Either disco the fuel lines with quick disconnect tools or flip it up and back when you remove the rail from the intake. You pull the rail gently but steady straight up. Remove the retaining clips from the injectors. Wiggle the injectors a bit as you pull them out. Be sure that all o-rings come out with the injector.
Old Aug 15, 2009 | 05:01 PM
jimg's'93's Avatar
jimg's'93
No need at all to disconnect the fuel lines. Put a towel on the windshield and you can just flip it over onto the towel.
Old Aug 15, 2009 | 06:03 PM
pianoguy's Avatar
pianoguy
Open the gas cap and also relieve the pressure at the schrader valve. I flip the fuel rail over onto a towel laying on the coolant surge tank. Pull the forward injectors out first and have a container ready to drain remaining fuel from the rail.
Old Aug 16, 2009 | 10:29 AM
hgh pwr's Avatar
hgh pwr
already have the fuel rail off the intake,left the fuel lines attached my question is how hard are the clips that hold each injector to the rail to remove,just want to replace the o-rings while the car is apart.
Old Aug 16, 2009 | 10:47 AM
pianoguy's Avatar
pianoguy
The clips should just slide to one side - just push on the little "ears", shouldn't take much force to pop them loose. Then just wiggle the injector out, and make sure the o-ring comes out with it. I used dish soap to lube the new o-rings.
Old Aug 16, 2009 | 12:10 PM
LT1*C4's Avatar
LT1*C4
I did an injector swap a few weeks back and took some photo's of the process. Here's the link to the that thread. Hope it helps.
http://forums.corvetteforum.com/c4-t...up-within.html
To injector removal
