Dipstick tube question.
Old Feb 17, 2002 | 02:02 PM
85z51vette's Avatar
85z51vette
Default Dipstick tube question.
The block I plan on using for my rebuild is a 3970010 casting. It is an earlier block, 2 bolt, and has a high nickel content. I found that by the markings on the front. It is stamped "10/20", which turns out to mean 10% tin and 20% nickel. Anyway, the dipstick is on the driverside, the original was on the passenger. Do any of you foresee any problems with this? TIA.. :cheers:
Old Feb 17, 2002 | 02:18 PM
Guest
Guest
Posts: n/a
Default Re: Dipstick tube question. (85z51vette)
I am using a 79, 4-bolt main truck block and have the dipstick on the drivers side now. Picked up the Lokar billet dipstick for it, works well. I running TPIS headers though, don't know if it will be a problem with stock header air tubes. Centainly, anything could be adjusted and I wouldn't hesitate getting the block for that reason. HTH
Old Feb 19, 2002 | 03:45 AM
85z51vette's Avatar
85z51vette
Default Re: Dipstick tube question. (Mark84_L383)
Did you use the oil pan from the truck? The block I have didn't have a pan on it, so I need to know what will work. Thanks a lot.
:cheers:
Old Feb 19, 2002 | 11:52 AM
85z51vette's Avatar
85z51vette
TTT. :crazy:
Old Feb 19, 2002 | 12:01 PM
Bob86ZZ4's Avatar
Bob86ZZ4
Get a good road race pan. I got mine from http://www.champpans.com. Give them a call. They were $100 cheaper than Canton or TPIS and it is a great pan. Very high quality.
To Dipstick tube question.
