Feul pressure on 383 Lt-1
Old 02-17-2002, 05:51 PM
Kehrer923
Kehrer923's Avatar
Default Feul pressure on 383 Lt-1
Does anyone know what a good starting point would for a 383? I have the tpis in tank HD feul pump, and 26 lbs injectors.
Old 02-17-2002, 06:22 PM
ChrisB
ChrisB's Avatar
Default Re: Feul pressure on 383 Lt-1 (Kehrer923)
Unless you specifically need "more injector" I would set the fp to whatever the injectors were rated at (probably 43.5psi) and program you computer for the proper size injector constant. The only reason to increase fuel pressure would be if you were maxing out your injectors - a/f tuning should be done within the pcm.
Quick Reply: Feul pressure on 383 Lt-1
