'870-'165 swap
Old Aug 17, 2009 | 12:03 PM
dclafleur's Avatar
dclafleur
Default '870-'165 swap
I'm looking into swapping ECM's and have found some good write ups but I'm curious how this will affect my 4+3 transmission.
I have an early 4+3 with a console switch that I usually leave off and hit the switch when I want to drop down into 4th overdrive.
Anything special I have to do to allow the 4+3 to work correctly?
Old Aug 17, 2009 | 02:40 PM
tequilaboy's Avatar
tequilaboy
Good question.
I would suggest that you configure the 165 ecm's connector like an 87-88 rather than an 86. This will permit the first gear switch to function and also permit use of normal 87-88 $32B bins.
Since 86's have no first gear switch, and the shifter switch is wired to the pin that 87-88s use for the first gear switch, wiring the ecm like an 86 would be problematic. Sorry I don't have the pin numbers handy. I should be able to dig them up, if you don't have a good 87-88 pinout available.
86 ecm pins:
M/T O/D Shifter switch: C8
O/D TCC Control: A7
A/T O/D switch: C7 (open in OD,N,R or P)
87-88 ecm pins:
M/T O/D Shifter switch: C7
O/D TCC Control: A7
M/T 1st gear switch: C8
The M/T O/D switch on the shifter is on pin C8 for 86, and C7 for 87-88.
To configure like an 87-88:
Connect your existing 85 1st gear switch wire to ecm pin C8.
Connect your existing 85 console switch wire to the ecm pin C7.
Note: The operation maybe different since the later shifter switch is only a momentary switch. I'm assuming that the 85 style console switch latches either on or off.
I would also program the OD to be off by default in the new bin and then use the console switch like a momentary switch to trigger the OD when desired.
Old Aug 19, 2009 | 03:49 AM
rodj's Avatar
rodj
Or if you care to do away with the kickdown function, bypass the ECM control altogether and switch the O/d relay directly from your existing switch. Full manual control .
Old Aug 19, 2009 | 11:32 PM
1BAD88's Avatar
1BAD88
OP's sig says that he has an 85 - didn't they use a TV cable to control the OD not the ECM?
I read on another 4+3 site (5speed.com?) that the 86 cars were the only year without a 1st gear switch.
Either way, it sounds like they could upgrade to the 88 bin.
-J
Old Aug 21, 2009 | 06:56 PM
dclafleur's Avatar
dclafleur
-J
I have no issue with full manual control, I really limit the OD to highway cruising.
I do belive that my kickdown is handled by a TV cable on the front of the throttle body. So does that mean regardless of ECM programming that my 4+3 will act the same way?
Old Aug 22, 2009 | 09:28 AM
rodj's Avatar
rodj
Having only owned a '87 with ECM control of kickdown I was of the same belief but I have been questioned when I posted up that info. Some stated it controlled line pressure?.
In either case it makes no difference to you as you will have it hooked up and you will find out 1st time you drive it.
To '870-'165 swap
