C-4 Brakes sticking
Old Aug 19, 2009 | 12:10 PM
donhughes's Avatar
donhughes
4th Gear
Default C-4 Brakes sticking
Hopefully someone can help me out. I have a 1994 Corvette@ 68k miles
It sat for a yr. Put it on road, brake pedal hard as rock. I figured must be brake booster, replaced it, pedal felt better . Now all four brakes seem to be sticking.I have Gravity bled brakes, Pressure bled brakes .
Read somewhere it could be the rubber hose coming off lower side of master cylinder collapsing. Guess I'll try that next. Seems strange that all 4 brakes are hanging up though. Then of course once it cools down its good for another 2 miles. Somebody help me figure this out.
Thanks, DL
Old Aug 19, 2009 | 12:13 PM
94z07fx3's Avatar
94z07fx3
Try it with the ABS/ASR fuse pulled or with one wheel speed sensor disconnected.
Old Aug 25, 2009 | 07:08 AM
donhughes's Avatar
donhughes
4th Gear
In case someone else has a similiar issue, mine ended up being a booster rod adjustment
To C-4 Brakes sticking
