Front lift
Old Aug 19, 2009 | 01:58 PM
sunnfish's Avatar
sunnfish
Default Front lift
I have a 86 and I was wondering if anybody has any idea on how to lift the front 1 or 2 inches. I just want a little more clearance on the air scoop. I have it just about rubbed off.
Old Aug 20, 2009 | 07:46 AM
gerardvg's Avatar
gerardvg
Default re raising front suspension
Hi
You can put shims in the spring mounting under the engine crossmember
However that may give you a quarter of an inch tops ... I got sick of trying different leaf springs and got some koni adjustable coil overs .. the ride improvement is amazing and less tyre wear .
Now i can set the ride hight however i want and the car is flater around corners .. reduces body roll as well with the multiple settings avail
Go for it you wont regret it
Old Aug 20, 2009 | 08:15 AM
jon0108's Avatar
jon0108
just cut an inch off the air scoop.Last time my car was on a lift I used my mechanics whiz wheel and cut about one inch off my front air deflector. I used masking tape and a white grease pen to make a one inch mark on the deflector for a straight cut.
To Front lift
