changing header gasket on 92 lt1 (driver)
Old Aug 19, 2009 | 03:34 PM
stevenbrian's Avatar
stevenbrian
Default changing header gasket on 92 lt1 (driver)
I have an exhaust leak, sounds like header gasket, on driver side on my 92 lt1. What is involved in this repair or could it be something else. i was told recently that those manifolds tend to blow out the 2,3 ports on that side. (i dont know the exact number but the two middle ones) any help would be appreciated before i start tearing into it.
Old Aug 19, 2009 | 07:24 PM
jaa1992's Avatar
jaa1992
From: Life is just one big track event. Everything before and after is prep and warm-up and cool-down laps
Cruise-In III Veteran
Cruise-In IV Veteran
St. Jude Donor '12
Header gasket on driver side is easy.
just move the ASR, unbolt the couple of support brackets, unbolt the header, move it a little, pull the old one out, put the new one in and bolt it all back up.
Not a lot of torque on the bolts, I found a combo gear wrench was easiest.
You may need to pull the plugs as well.
Old Aug 19, 2009 | 08:27 PM
stevenbrian
thanks man, it didnt look that complicated. i thought maybe id have to remove the alternator maybe. Have you heard of anyone having exhaust leak issues in that area?
Old Aug 20, 2009 | 08:39 AM
jaa1992's Avatar
jaa1992
St. Jude Donor '12
I didn't when I replaced my head gaskets at 102K
To changing header gasket on 92 lt1 (driver)
