Low temp fan switch info needed
Old Aug 20, 2009 | 08:43 PM
tblt44's Avatar
tblt44
Default Low temp fan switch info needed
1995 vette
How many of you have installed a low temp fan switch?
I was looking at the 200 switch
I don't like my vette getting up to 227 before the fans kick on.I live in florida and when sitting in trafic it stays hot unless I use the air than the fans run all the time.
With this swith will the fans still come on when I turn the air on even before the 200 deg.
Anyone have any problems installing or with these switches
Old Aug 20, 2009 | 09:16 PM
BADDUCK's Avatar
BADDUCK
From: One day you're a Comet...the next day you're dust... Arkansas
I don't think you have one. Aren't your fans both controlled by the ECM.
Old Aug 20, 2009 | 09:35 PM
tblt44's Avatar
tblt44
I think it is but they sell this switch that installs in a water jacket hole.I guess it will come on before the computer turns it on.
http://www.parts123.com/parts123/yb....Z5Z5Z50000050F
Old Aug 20, 2009 | 10:51 PM
rodj's Avatar
rodj
So long as you wire it in parallel so the ECM still has control of the fans.
(Best way because fans will still run at normal temp if switch fails )
If you wire it standalone then the only thing that will turn the fans on is the switch itself.
Old Aug 21, 2009 | 07:25 AM
toptechx6's Avatar
toptechx6
I used the switch before getting my chip reprogrammed and it worked fine, it will however set code 28 for the quad driver module circuit. That code will not illuminate the SES light, but just understand it will happen so you are not confused when you see it in memory.
Looking back I would just get the PCM tuned especially on your 95 since you can likely gain a few ponies at the same time by tuning for 93 octane fuel. If your car is automatic they can also firm up the shifts at the same time.
PCM For Less is highly regarded by many, I have used Ion Soltan
http://www.madtuner.com/ and was happy with the results.
Old Aug 21, 2009 | 08:19 AM
TWISTERUP's Avatar
TWISTERUP
Reprogramming is the way to go. also 95/96s operate different then earlier C4s...they run in tandem and have a low and high speed contolled entirely by the ECM by monitoring the ECT sensor which is used for closed loop and fuel trim. I don't see how.... short of replacing the ECT w/one of different temp/resistance range (which would also change fuel trim) you would maintain the low and high speed functions. If the 95 came factory equipped with a seperate fan temp sensor i could see it working fine but IMO it doesn't. Go for the reprogamming or leave it alone. JMO
Old Aug 21, 2009 | 09:37 AM
theadmiral94's Avatar
theadmiral94
From: 1994 LT1 Coupe 6-speed with FX3 & 2000 LS1 Vert 6-Speed with F45 Hunterdon County, NJ
One other reason to NOT use this switch is that the fans will likely NEVER turn off.
I would guess your digital dash's coolant temperature never gets below 194 F (the stock thermostat's typical 'water pump' coolant temperature).
That temperature is derived from a sensor mounted in the water-pump.
However, in a 1995, the temp in the water pump will always be lower than other parts of the engine (e.g. where this switches sensor might be installed) as cooler water is being mixed with the engine hotter water therein.
To Low temp fan switch info needed
